Suspension & Brakes Theory, alignment, spring rates....
after market rear sway bar end links?
Old Jun 26, 2005 | 08:09 PM
kcem1's Avatar
Default after market rear sway bar end links?
Was wondering if any company makes end links or are the factory ones from a 00 civic si as good as it gets. tried searching and found nothing any help would be great.
Old Jun 27, 2005 | 09:59 AM
tsispyder97's Avatar
If you are talking about the long bolts nad 4 sets of bushings and cups, energy suspensino makes them.
Old Jul 24, 2005 | 10:31 PM
ArinX's Avatar
Default Re: after market rear sway bar end links? (kcem1)
i know someone makes em, because i saw a set on ebay.
The guy said they were aftermarket but when i e-mailed asking who made it he pretended to not know what auction i was talking about.
Old Aug 31, 2005 | 04:25 PM
adrenajunky's Avatar
Default Re: after market rear sway bar end links? (ArinX)
energy makes front swaybar endlinks and the bushings are ok but the hardware they give you is junk. i replaced my fronts and it feels sloppier than the worn out stock ones. anyone else had that problem? i have yet to find rear swaybar endlinks.
Old Aug 31, 2005 | 05:11 PM
chrisw85's Avatar
Adrena, i assume you got the front endlink kit for DC2/EG, comes with new poly bushings (8 total, 4 each side) and bushing 'cups'/washers and bolt and nuts and spacers. The front endlinks from energy for DC2/EG is part # 16.8104 and are about $13.
I've installed it on my bros 94 civic, and it felt much better. They key is not to wrench on the nut all the way; this will crush the poly bushigns too much it even shows this in the picture they give you. I tightened it just enough where it'd contact the bushings but no further.
Old Aug 31, 2005 | 06:53 PM
Default Re: (chrisw85)
oh. ha ha. i torqued them dwn w/ with impact gun
Old Aug 31, 2005 | 07:27 PM
Domani_Vi-RS's Avatar
aftermarket, i believe srr makes a good one. as for OEM: i hear CTR ones are quite fat and it's oem so you know it's a good quality one
Old Aug 31, 2005 | 07:59 PM
lowgman's Avatar
http://www.a-spec-racing.com has aftermarket endlinks for the 00 si. The site is down right now, but get in touch with Charleston once the site is back up. Good guy
Pompiuses
Sep 1, 2021 10:39 AM
makoto
Suspension & Brakes
Jul 21, 2008 12:25 PM
Mikes2000civicsi
Suspension & Brakes
Mar 27, 2008 10:17 PM
luvtositdumpt
Suspension & Brakes
Jan 30, 2008 08:10 AM
