motor swap question TYPE R
Old Jun 26, 2005 | 06:44 PM
MaGoodc2's Avatar
Default motor swap question TYPE R
I dont know if its just a rumor or not, but im going to swap a jdm itr engine in my ek but I heard the jdm itr axels are diffrent then the usdm itr axels. Is this true?
Old Jun 26, 2005 | 07:34 PM
Above6K's Avatar
Default Re: motor swap question TYPE R (MaGooEG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MaGooEG6 &raquo;</TD></TR><TR><TD CLASS="quote">I dont know if its just a rumor or not, but im going to swap a jdm itr engine in my ek but I heard the jdm itr axels are diffrent then the usdm itr axels. Is this true?</TD></TR></TABLE>
No, not true. If your getting a complete swap the axles that come with the engine will be just fine. Where are you getting the swap from BTW?
SleepnCiViC's Avatar
i have never heard this, but get a 2nd opinion
Old Jun 26, 2005 | 08:37 PM
BlueIntegraBoy's Avatar
Yes, the spline is larger (36mm) on the 98 Spec ITR axles. The USDM ITR axles have a 32mm spline. If you want to run the bigger spline, you'll need the JDM 5-lug conversion. But you can always run any USDM B-series axles with your swap.
Old Jun 26, 2005 | 08:40 PM
Stoich EG2's Avatar
Default Re: motor swap question TYPE R (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">Yes, the spline is larger (36mm) on the 98 Spec ITR axles. The USDM ITR axles have a 32mm spline. If you want to run the bigger spline, you'll need the JDM 5-lug conversion. But you can always run any USDM B-series axles with your swap.</TD></TR></TABLE>
Old Jun 27, 2005 | 07:02 AM
MaGoodc2's Avatar
Default Re: motor swap question TYPE R (Advan06)
ok so you guys are saying if I get a complete jdm itr swap that came with the bigger axles I can use those with my four lug stuff, But if I brake one of the axles I can just simple replace it with any usdm b-series axle and it will work just fine despite one bigging larger then the other. (Maybe I should just do a ctr swap like I did in my eg.) I didnt have any problems with that
Old Jun 27, 2005 | 07:05 AM
MaGoodc2's Avatar
Jessm985's Avatar
I'm pretty sure he's saying that if you'll have to do a JDM 5 lug conversion in order to use the axles that will come with the JDM swap. It'd probably be much easier for you to find some USDM B series axles.
Old Jun 27, 2005 | 07:07 AM
MaGoodc2's Avatar
Default Re: motor swap question TYPE R (Jessm985)
ya I just read it again and It made since. Its early for me still. Ya see thats what I been hearing and just wanted to make sure it was true. Thanks guys
Old Jun 27, 2005 | 07:31 AM
JDM-EJ1's Avatar
WHAM! We have a winner!!
Old Jun 27, 2005 | 09:59 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: motor swap question TYPE R (JDM-EJ1)
All USDM ITR swaps have smaller 32mm axles.
96-97 JDM ITR swaps have the smaller 32mm axles.
98+ JDM ITR swaps have the larger 36mm axles.
Old Jun 27, 2005 | 11:58 AM
Above6K's Avatar
****, I stand corrected..Learn something new everyday.
JDM_ITR
Jun 12, 2006 09:09 AM
hondacivichatch
Sep 25, 2005 12:33 PM
Terrible One
Mar 19, 2005 06:19 AM
cvclover
Feb 4, 2004 07:51 AM
