92 gsr shaking very bad under wot
Old Jun 26, 2005 | 05:08 PM
1SOL2NV's Avatar
Default 92 gsr shaking very bad under wot
ok guys heres whats up.Car has 2 new axles and nothing is loose or bent with the suspension,but under half or wot the car shakes and virbrates really bad do you guys have any suggestions if i left something out that you need to ask......do so and i'll answer thanks in advance
Old Jun 26, 2005 | 05:54 PM
kkim's Avatar
Default Re: 92 gsr shaking very bad under wot (1SOL2NV)
does it still vibrate after you get to speed and let off the gas? did this problem start after you put in the new axles? where did you get the axles from?? rebuilt?
my guess is that one of your axles or both are bad. I changed out one axle a few weeks ago and the replacement rebuilt axle did exactly what you are describing. took it back, got another rebuilt axle from them and all is fine.
Old Jun 27, 2005 | 07:11 PM
Kusai.Nihonjin.Desu's Avatar
Default Re: 92 gsr shaking very bad under wot (kkim)
Good point, since it wasnt doing this with the old axles...right, D?
Old Jun 27, 2005 | 08:02 PM
1SOL2NV's Avatar
um the car doesnt do it execpt when throttle is applied. it was an advance axle so i think its a rebuild
Old Jun 27, 2005 | 08:18 PM
kkim's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1SOL2NV &raquo;</TD></TR><TR><TD CLASS="quote">um the car doesnt do it execpt when throttle is applied. it was an advance axle so i think its a rebuild</TD></TR></TABLE>
exactly what I was experiencing. if it came from a parts store, they could have a lifetime warrenty on the axles. check and if they do, determine which one is bad and return it and get another one.
slkleltlclh
Nov 8, 2006 09:36 PM
John.
Jul 28, 2006 10:56 AM
b18bfreak
Aug 2, 2004 10:05 AM
fred92htch
Jul 10, 2002 02:07 PM
Prelussion
Nov 15, 2001 12:51 PM
