sqeaky clutch pedal spring
Old Jun 26, 2005 | 02:01 PM
Crimson_Tide's Avatar
Default sqeaky clutch pedal spring
every time i push in the clutch pedal or let it out i hear a sqeaking noise come from under the dash... i pushed the clutch pedal in with my hand(stock clutch... lol) while the car was off and with my head under the dash and it sounds like its coming from the spring on the clutch pedal... i sprayed some lube on it but to no avail... besides replacing the spring is there any way to fix this? thanks
-Josh
Old Jun 26, 2005 | 02:11 PM
PURPLETERROR aka BIGMATT's Avatar
Default Re: sqeaky clutch pedal spring (Crimson_Tide)
Lube the pivot point on the pedal.
Old Jun 26, 2005 | 02:48 PM
dh's Avatar
dh
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crimson_Tide &raquo;</TD></TR><TR><TD CLASS="quote">every time i push in the clutch pedal or let it out i hear a sqeaking noise come from under the dash... i pushed the clutch pedal in with my hand(stock clutch... lol) while the car was off and with my head under the dash and it sounds like its coming from the spring on the clutch pedal... i sprayed some lube on it but to no avail... besides replacing the spring is there any way to fix this? thanks
-Josh</TD></TR></TABLE>
LOL I got the same problem. Never really bothered me though.
Old Jun 26, 2005 | 02:52 PM
Kryogen's Avatar
Yeah same problem here...if you actually want to call it a problem.
they are old cars, you cant expect everything to be perfect...hence why I have never even bothered trying to fix mine.
Old Jun 26, 2005 | 03:45 PM
StupidSlowRSX's Avatar
Default Re: (Kryogen)
Bump for a solution to this annoying problem.
Does that lube **** really work, or is it just an idea.. I've tried using WD-40 with no success
Old Jun 26, 2005 | 04:25 PM
Lo-Buck EF's Avatar
Default Re: (StupidSlowCRX)
wd get some white spray lube.
Old Jun 26, 2005 | 07:01 PM
FalkenSiR's Avatar
Default Re: (Lo-Buck EF)
white lithium grease. Don't know where to get it because I had it laying around, but it worked awesome. No more squeaks. You apply some at the cable hook.
Old Jun 26, 2005 | 09:44 PM
CRXDrew's Avatar
White lith as said before... any autoparts store. Great to use when lubeing up door hinges and suspension stuff. Since I live near Chicago we get a ton of Salt ans **** on the roads. I keep my suspension clean, anti-seized and white lith covered
jaymua
Jul 24, 2006 02:10 AM
The Weather Man
Sep 19, 2005 06:29 PM
sohctodohc
Nov 27, 2004 11:42 AM
Paste
Aug 30, 2002 07:57 AM
vtecdc2
Apr 30, 2002 09:47 PM
