ecu problems code 21&22
Old Jun 26, 2005 | 01:51 PM
5genhatch's Avatar
Default ecu problems code 21&22
just swapped a 98 itr motor in my 93 civic vx. car idles rough, but smoothes out as i give it throttle. cel is telling me code 21 and 22. vtec spool solenoid and vtec pressure valve. does any1 know how to fix this. where is the vtec spool solenoid and vtec pressure valve located. maybe i have the wrong plugs hooked up...
thanx
Old Jun 26, 2005 | 02:12 PM
MidoriBG96's Avatar
Default Re: ecu problems code 21&22 (5genhatch)
I had a CEL 21 too, check your wiring at your ecu harness. Mine just wasn't touching enough. After that check your solenoid, its at the end of the valve cover at the foreward most cam
Old Jun 26, 2005 | 02:22 PM
5genhatch's Avatar
ok im down to cel 22 only. have no idea how to fix this one
need help!!!!!
denraweb
Aug 22, 2007 03:14 PM
AdamQ3B85
Sep 9, 2005 04:10 AM
DohctorVtec
Jul 5, 2005 01:35 PM
Fuster_Cluck
May 15, 2003 10:05 AM
RoaringTurtle
18
Aug 5, 2002 01:17 PM
