2.75" intercooler with 2.5" piping?
Old Jun 26, 2005 | 12:47 PM
the.hamburglar's Avatar
Default 2.75" intercooler with 2.5" piping?
ok im going to run a 2" pipe from the turbo to the ic and then flare it at the ic to 2.75" (if possible). and then im going to run a 2.25" pipe from the ic to throttle body and then flare it to 2.75" at the ic and then flare it to 2.5" at the throttle body. is this a good idea?
Old Jun 26, 2005 | 02:50 PM
ndogg's Avatar
Default Re: 2.75" intercooler with 2.5" piping? (hamburgler)
i just run 2.5 everywhere.
Old Jun 26, 2005 | 03:04 PM
BlueShadow's Avatar
IMO if you are just running a moderate setup this is what you should do:
2" piping between compressor outlet to IC inlet
2" IC inlet
2.25" IC outlet (or 2.5" if you think you might be going with a bigger setup in the future)
2.25" piping on the IC outlet side (or 2.5" to match a 2.5" IC outlet)
Now the part about the flare, I think you should just get a transition hose and the correct size T bolt clamp. If you take it to a really good welding shop you can have them weld in a transition pipe, just dont take it to some back alley welding shop. I have a 2.25" IC pipe and a 2.75" TB. My transition hose fits snugly around the pipe, and I'm actually more concerned with the seal on the TB. But I used some T bolt clamps and tightened them down good, so there shouldn't be any leaks.
Old Jun 26, 2005 | 03:13 PM
ReDHaTcHyGuy's Avatar
Default Re: 2.75" intercooler with 2.5" piping? (BlueShadow)
yeah they make silicone couplers that go from 2.5-3 and such so u can step it up to fit the ic on one side and the pipe on the other ..thats what my buddies just did on his setup , basicallly what the last guy told u
Old Jun 26, 2005 | 06:02 PM
Default Re: 2.75" intercooler with 2.5" piping? (ReDHaTcHy97)
why not just flare it? i think im going to go with a 2.5" intercooler. i dont know anyone who makes and intercooler with 2" in and 2.25" out.
Old Jun 26, 2005 | 08:00 PM
BoOsTiN Dc2's Avatar
what about 2.25 piping all around and 500-550 hp? would that not be such a good idea?
Old Jun 26, 2005 | 08:17 PM
Default Re: 2.75" intercooler with 2.5" piping? (tRaCeBuStAbUsTeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tRaCeBuStAbUsTeR &raquo;</TD></TR><TR><TD CLASS="quote">what about 2.25 piping all around and 500-550 hp? would that not be such a good idea? </TD></TR></TABLE> it wouldn't really hurt anything ... the coupler i was talking about are basically flared the taper from one size to another
Old Jun 26, 2005 | 11:56 PM
BlueShadow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hamburgler &raquo;</TD></TR><TR><TD CLASS="quote">why not just flare it? i think im going to go with a 2.5" intercooler. i dont know anyone who makes and intercooler with 2" in and 2.25" out.</TD></TR></TABLE>
Because it will be more expensive then just buying a transition hose.
A conical aluminum transition pipe costs around $28 from burnsstainless.com. Then a 2.75" section of aluminum pipe to butt up to your TB will cost about $12. Then you figure $30-$75 to have someone TIG weld it together.
jbell
Nov 15, 2008 12:54 PM
JM Performance
Jan 1, 2004 08:02 AM
SIReg9
Jul 21, 2003 01:07 PM
jthelman
Feb 15, 2003 11:32 PM
blufke
Oct 25, 2002 03:31 PM
