AEM Pulley install...engine out?
its pretty easy, you might not want to install that alternator pulley, when i had mines in, it would not produce enough current at idle, therefore draining straight out of the battery causing me to have a dead battery, and also if you have a sound system, i would not recommend that alternator pulley
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude »</TD></TR><TR><TD CLASS="quote">its pretty easy, you might not want to install that alternator pulley, when i had mines in, it would not produce enough current at idle, therefore draining straight out of the battery causing me to have a dead battery, and also if you have a sound system, i would not recommend that alternator pulley</TD></TR></TABLE>
The exact same thing was happening to me. It was cool the first month or two, but after awhile, my battery would start to die, so I'd have to drive in a low gear to keep current going to my battery. I took it off a few weeks ago, and havent' had any problems since...
Draggin99Si
Aug 28, 2004 06:02 PM
