Rear disc conversion?
Old Jun 26, 2005 | 08:18 AM
d16rice's Avatar
Default Rear disc conversion?
I am searching for it right now, but I would appreciate if you could save me some time and answer some of the questions.
1) Did a 92-95 Civic LX come with rear disc brakes?
2) If so, would they fit a 1997 civic hatchback?
3) If it’s possible, what parts do I need to make it work?
4) What tools?
Old Jun 26, 2005 | 08:21 AM
pdiggitydogg's Avatar
Save you time by wasting others?
All rear disc parts are the same (minus itr).
Integra 91-01 Civic 92-00 Del Sol 93-97
Get trailing arms, hubs, rotors, pads, cables, hoses, prop valve
All will work.
...Search...
Old Jun 26, 2005 | 09:32 AM
d16rice's Avatar
Default Re: (pdiggitydogg)
Does LX even come with rear disc brakes?
I tried searching, but couldn’t find a definite answer.
I found a 92-95 4-door in a local junk yard.
It has an LX badge and a non-vtec engine (obviously).
It has steel wheels with hubcaps, so I couldn’t see for sure what rear brakes it has, but from the gaps, it looked like it had a rotor and a caliper in the back. Is this possible?
The guy said that if I wanted the rear assembly, I could have it for $80.
Old Jun 26, 2005 | 09:46 AM
If its abs then probably - pop the hood and look for the abs parts
You could also just look behind the wheel and see drums or a disc
Old Jun 26, 2005 | 09:55 AM
d16rice's Avatar
I'll try checking that.
Could I just swap the hubs, or would I need the trailing arms too?
Where is the prop valve located?
XXXXX
The civic at the junk yard is a 1992 civic LX (sedan) with 4-wheel disc brakes and ABS.
Modified by d16rice at 1:06 PM 6/26/2005
Old Jun 26, 2005 | 10:43 AM
Yes you can just swap hubs
Proportioning valve is located on the firewall (has all hardlines running to it)
ALL this is readily available by searching a little harder
Old Jun 26, 2005 | 12:45 PM
d16rice's Avatar
I found a bunch of post of people selling the swap, a few posts of people discussing why they should/shouldn't do it, but no how-to's.
I would appreciate if some one could post me a link of a HOW-TO for a rear disc brake conversion (EG brakes on EK hatch). How-to's with pictures would be most helpful.
Old Jun 26, 2005 | 01:42 PM
..........omg............
Sort by catagory and you wont get any results for ones being sold
In just civic alone, there are 309 results for rear disc. Read a little and you find:
http://repo.jackmoves.com/album55
https://honda-tech.com/zerothread?id=426445
https://honda-tech.com/zerothread?id=812062
https://honda-tech.com/zerothread?id=641639
https://honda-tech.com/zerothread?id=1036267
Lazy turd
steelhitman1245
Nov 7, 2011 06:53 PM
wlp2nd
Suspension & Brakes
Nov 2, 2009 03:14 PM
area608EG
May 17, 2008 05:39 PM
aznsmtboy
Dec 7, 2007 04:36 AM
mandelo
Jun 15, 2004 12:08 PM
