F.S.OEM rear sway bar for ITR
I have an OEM rear sway bar for an ITR for sale. 22mm brand new, new used! Still in plastic and in the original Honda box in came in. Again it's just the 22mm rear sway bar, nothing else! $60 shipped
dude 60.00 shipped for a 125.00 piece is incredible deal
All I will need is the BSQ kit and 22mm bar right? Just some drilling and I can use the nuts and bolts from the GSR?
You'll need the endlink thingy that will hold the bar at in place too.
Check out BSQ's website. It has a full list of everything you need.
http://geocities.com/bretq/swaybar_install.html
I got mine for $80 including all that stuff + $20 for BSQ's kit, so $100 total. I think $60 is a pretty good deal.
The sway bar with all that tiny stuff? I got it here in the "Classifieds" and it was used.
But it's not like there's much of a difference between brand new and used. It was a little dusty, but once I cleaned it, it was as good as new.
EDIT: This is BSQ's post--
"You can get all of the Acura parts (ie. Type-R rear swaybar, bushings, brackets, misc. nuts and bolts) from A&H Motorsports ( http://www.ahmotor.com ) for approx. $100 shipped. You can get the Type-R rear swaybar mounting kit from myself ( http://www.geocities.com/bret/mounting_kit.html ) for $20 shipped. So you are looking at a total cost of approx. $120 for everything to install the Type-R rear swaybar."
HTH
[Modified by Calavera, 9:45 AM 2/13/2002]
HTH
dj theoretic
11
Jan 18, 2009 11:49 AM
