Firing order
Old Jun 26, 2005 | 02:47 AM
UNKNOWN_MEMBER's Avatar
Default Firing order
Why is my firing order different then this? I tried this one and my car didn't start. Tried on my friend that works for honda told me and worked. It's like crossed. 1 is where 4 is, 2 is where 3 is, 4 is where 1 is, and 3 is where 2 is. so it's 1-2-4-3, instead of 4-3-1-2. Can anyone elaborate?
Old Jun 26, 2005 | 07:15 AM
PURPLETERROR aka BIGMATT's Avatar
Default Re: Firing order (UNKNOWN_MEMBER)
your dizzy is 180 out, did you recenty remove it? or dissassemblle it in the past?
Modified by PURPLETERROR at 10:39 PM 6/26/2005
Old Jun 26, 2005 | 09:47 AM
Touge Tuning's Avatar
how does ur dizzy become 180 out and how do u fix it? woudl it cause the car to run differently?
Old Jun 26, 2005 | 01:37 PM
PrettyLude's Avatar
your dizzy becomes 180 out when you don't stab it in right, and yes it will cause the car to run different
Old Jun 26, 2005 | 01:52 PM
hmmm because i dont think my plug wires are setup that way and ive never removed the dizzy. Also the car ran fine but now its giving me problems when i swapped it from my hatch to my coupe so im wondering if being in a different car has affect it?
Old Jun 26, 2005 | 04:01 PM
Combustion Contraption's Avatar
Most honda dist. keys are made so that you cant install them 180 degrees out, the dist. wont sit flush.
Old Jun 26, 2005 | 04:25 PM
Yes i took the dizzy apart, took ignitor and coil out but put all the wires back in the right way. So how did this happen?
Old Jun 26, 2005 | 04:29 PM
I dont know, you tell me.
Old Jun 26, 2005 | 09:09 PM
BoostedJeff's Avatar
Default Re: (LsVtec92Hatch)
Modified by BoostedJeff at 11:48 AM 6/27/2005
Old Jun 26, 2005 | 09:23 PM
RedlinedVTEC's Avatar
Default Re: (BoostedJeff)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedJeff &raquo;</TD></TR><TR><TD CLASS="quote">honda distributors are made so that you can have the key either way and it wont affect firing order </TD></TR></TABLE>
No that is just wrong. The rotor will be contacting a point that is two cylinders off of the injector pulse.
Old Jun 26, 2005 | 10:15 PM
Old Jun 26, 2005 | 11:57 PM
So could the dizzy be installed wrong? I tried rotating the rotor 180 and putting it on the cam and it won't go in.
Old Jun 27, 2005 | 01:33 AM
limpy's Avatar
Default Re: (UNKNOWN_MEMBER)
did you some how put the rotor on 180 out? is sounds like you have the dizzy on right if it wont go on when you rotated it.
Old Jun 27, 2005 | 02:47 AM
Default Re: (limpy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by limpy &raquo;</TD></TR><TR><TD CLASS="quote">did you some how put the rotor on 180 out? is sounds like you have the dizzy on right if it wont go on when you rotated it.</TD></TR></TABLE> Nope, it only slides in easily one way. wierd.... . And when my friend ask his co-workers they said they always used this firing order.
Old Jun 27, 2005 | 08:16 AM
ahhh found the problem. Original owner of the motor put the key on the dizzy 180 wrong way. So i had to take the pin out then move the key 180 degrees and put the pin back in.
soodominican
Jun 16, 2008 08:30 PM
Warren
Apr 6, 2007 06:49 AM
WestEM1
Mar 30, 2005 07:47 AM
Qwikrex
12
Mar 16, 2003 10:57 AM
