2.25" vs 2.5" piping on b18c1 92 cx
Old Jun 26, 2005 | 12:30 AM
civicsareslow's Avatar
Default 2.25" vs 2.5" piping on b18c1 92 cx
which one will give better results for a 92 hatch with usdm b18c1 w/ intake and header? also, is the piping on the apexi worldsport 2.25"?
Modified by civicsareslow at 1:45 AM 6/26/2005
Old Jun 26, 2005 | 06:32 AM
99exd16y8's Avatar
Default Re: 2.25" vs 2.5" piping on b18c1 92 cx (civicsareslow)
bump
Old Jun 26, 2005 | 07:03 AM
PURPLETERROR aka BIGMATT's Avatar
2.5, along with a header with a 2.5 inch collector
Old Jun 26, 2005 | 10:27 AM
Default Re: 2.25" vs 2.5" piping on b18c1 92 cx (PURPLETERROR)
why 2.5?
Old Jun 26, 2005 | 12:28 PM
onefstek's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicsareslow &raquo;</TD></TR><TR><TD CLASS="quote">why 2.5?</TD></TR></TABLE>
because its biger then the 2.25" and along with a 2.5" collector header, will give you a good flow.
Old Jun 26, 2005 | 12:39 PM
MugenHonda's Avatar
From: With my POS D15B2, Whereever whenever, United States
Default Re: 2.25" vs 2.5" piping on b18c1 92 cx (onefstek)
i say 2.25 if it is stock and maintain stock
2.5 should only be used when you got cams
Old Jun 26, 2005 | 09:15 PM
Default Re: 2.25" vs 2.5" piping on b18c1 92 cx (MugenHonda)
i probably will build it a bit later in the future, so will there be a big power loss if i get 2.5 over 2.5 for an all motor set up?
Old Jun 26, 2005 | 09:18 PM
MugenHonda's Avatar
not really, but if you do get 2.5 you will lose some low end, because you don't have the cams to support it
Old Jun 26, 2005 | 09:21 PM
how much do cams cost anyway?
Old Jun 26, 2005 | 10:02 PM
DohctorVtec's Avatar
I got 2.25 on my civic with b16a and its built and I still love the 2.25 dont want to go really any bigger atm...and cams can get pretty pricey depending on what stage you get
Old Jun 26, 2005 | 11:40 PM
Kyles ej1's Avatar
Default Re: 2.25" vs 2.5" piping on b18c1 92 cx (DoctorVtec)
get ctr or itr cams, theyre cheap and will make it pull harder
Old Jun 26, 2005 | 11:58 PM
Tad's Avatar
Tad
Default Re: 2.25" vs 2.5" piping on b18c1 92 cx (93ejay1)
might as well just go 2.5,
because then you can mod away without having to worry about upgrading your exhaust AGAIN later on.
But if you plan on staying with a stock motor, and just boltons,
i'd really say just stick with 2.25
at least thats what I think
Old Jun 27, 2005 | 01:27 AM
daver's Avatar
well now this all depends on goals. 2 1/4" should be plenty to flow any mildly modded gsr engine. I read somewhere thats this dia is good up to 180whp.
If you go 2.5" then you will lose low end power, regardless of the cams. it simply gives up more low end flow velocity, exhaust dia is all about compromise. You may be able to fuel tune some of that low end back tho.
I can see using the 2.5" to tie in with a 2.5" collector header (you don't want to down step), but these headers are meant to go with serious other mods.
d
Old Jun 27, 2005 | 06:49 AM
MR.M's Avatar
2.5
phoxking
Feb 7, 2012 08:42 PM
phoxking
Jun 9, 2011 07:54 AM
capthappy8p
22
Jun 19, 2008 05:16 PM
Ignitecivic
18
Jun 27, 2004 06:29 PM
