Suspension & Brakes Theory, alignment, spring rates....
D2 Coilover Install ..... in progress
Old Jun 26, 2005 | 12:25 AM
crxmadman's Avatar
Default D2 Coilover Install ..... in progress
hey guys, got my d2 coilovers (rears) on the CRX, but I totally forgot about the nut thats usually tack welded onto the back of the OEM shock (for the LCA-shock through bolt). Since D2 didn't pack a replacement nut, will any strength nut do just as well for replacement?
TIA!
Old Jun 26, 2005 | 09:09 PM
PIC Performance's Avatar
Default Re: D2 Coilover Install ..... in progress (crxmadman)
If you don't find out what to use (I'm not sure either), I went to my local Honda parts dept. and picked up the proper part per Honda OEM.
Old Jun 27, 2005 | 09:54 AM
tsispyder97's Avatar
Default Re: D2 Coilover Install ..... in progress (Noob4life)
take the stock bolt, go to Napa, and get the red bolt that is the same size and two nuts...put it on use the second nut as a safe for it backing off
ej888
Jun 7, 2010 08:06 AM
newbiehonda_05
Suspension & Brakes
Jan 14, 2008 05:54 AM
jbell
Jul 7, 2005 09:06 AM
crxmadman
Jun 26, 2005 02:32 PM
JFG Kevin
Jun 29, 2004 03:45 PM
