Power steering rack or manual rack?
Old Jun 25, 2005 | 11:16 PM
_Cyclone_'s Avatar
Default Power steering rack or manual rack?
Which steering rack weighs less... the manual rack or the power rack ? Or are they the same? I don't want power steering regardless.
EDIT : Is there a difference between the two in ratios and lock to lock travel?
Modified by CycloneBlue_1.6EL at 10:11 AM 6/26/2005
Old Jun 25, 2005 | 11:19 PM
neutron91's Avatar
Default Re: Power steering rack or manual rack? (CycloneBlue_1.6EL)
i would assume the manual rack would weigh less due to less parts involved
Old Jun 25, 2005 | 11:28 PM
_Cyclone_'s Avatar
Default Re: Power steering rack or manual rack? (neutron91)
They would have the same parts inside though, wouldn't they? The manual rack just wouldn't have fittings on it... or is there more to it than that?
Old Jun 25, 2005 | 11:31 PM
neutron91's Avatar
im pretty sure there is a difference in the lock to lock ratio but i dunno if there are more parts involved... my reasoning for the power rack weighing more was just cause of the fittings and small misc junk on em
Old Jun 26, 2005 | 06:10 AM
_Cyclone_'s Avatar
bump
Is there is difference in the ratios or lock to lock travel?
Old Jun 26, 2005 | 08:03 AM
wheels01's Avatar
Yes there is a difference lock to lock between the two racks. They are different internaly. I belive they also use different tierods. As for weight I do not know. The manual rack has less effort and a extra 1/2 turn lock to lock. (I believe 1/2, may be 1/4, been a while since I checked) The power steering rack is higher effort even without the pump, but is a quicker ratio. If you want the quickest ratio get the manual rack, and the quiafee conversion. That makes it a 1/4 turn quicker than a power rack. I havent used this setup yet. The only time in, day to day driving, a power rack without the pump seems to be a problem is parking. But even my girlfriend can handle it. I just finished the evolution school (Solo) and one of my instructer mentioned my steering was a little to stiff for tight slaloms.
Old Jun 26, 2005 | 08:58 AM
neutron91's Avatar
Default Re: Power steering rack or manual rack? (wheels01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wheels01 &raquo;</TD></TR><TR><TD CLASS="quote">If you want the quickest ratio get the manual rack, and the quiafee conversion. That makes it a 1/4 turn quicker than a power rack.</TD></TR></TABLE>
i sooo wanna try one of these out... inlinefour has them... i know someone will be asking where to get them
Old Jun 28, 2005 | 08:33 AM
wheels01's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neutron91 &raquo;</TD></TR><TR><TD CLASS="quote">i sooo wanna try one of these out... inlinefour has them... i know someone will be asking where to get them</TD></TR></TABLE>
I know I almost considered it when I re did my steering this year. But decided against it for a few reasons. First of all my steering is already stiff for parking, and I do still have to drive it daily Two energy suspensions steering bushings are for the power rack(better feel) Three my power box was still fine, just everything else was worn out.
Old Jun 28, 2005 | 12:18 PM
monicle's Avatar
its about 2.5 lbs heavier than the manual rack
Old Jun 29, 2005 | 05:38 AM
wheels01's Avatar
Default Re: Power steering rack or manual rack? (monicle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by monicle &raquo;</TD></TR><TR><TD CLASS="quote">its about 2.5 lbs heavier than the manual rack</TD></TR></TABLE>
are we talking straight box, or with the hoses and pumps?
Old Jun 29, 2005 | 09:41 AM
monicle's Avatar
thats just the rack cause thats what he was asking about.
Old Jun 29, 2005 | 10:43 AM
Jon V's Avatar
PS
and of course there is a difference lock to lock... It also depends which rack you are talking about. you know there is more than one right?
ITR PS rack&gt; ALL
Old Jun 30, 2005 | 07:24 AM
wheels01's Avatar
Default Re: Power steering rack or manual rack? (Jon V)
I'm not sure the ITR is the best. I thought it had a variable ratio depending on speed.
Old Jun 30, 2005 | 07:31 AM
Jon V's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wheels01 &raquo;</TD></TR><TR><TD CLASS="quote">I'm not sure the ITR is the best. I thought it had a variable ratio depending on speed.</TD></TR></TABLE>
how would that work? al the racks should have a set ratio, the ITR is just the closest (least turns lock to lock).
The 00-01 ITR and the 00-01 GSR racks are the same though...
I love my P/S
Old Jun 30, 2005 | 09:40 PM
wheels01's Avatar
Not sure but I know it is used on NSX and 02Civic SI, but they use an electric assist so it is much easier to do.
How many turns lock to lock is the Type R?
Old Jul 1, 2005 | 08:17 AM
Jon V's Avatar
3 TURNS LOCK TO LOCK...
Old Jul 1, 2005 | 04:42 PM
wheels01's Avatar
My 92 power rack is 3 1/4. That extra 1/4 would be nice for slaloms, but then I would have to install power steering again. That would be realy stiff without for parrallel parking. Its good to know though, my past searching seemed to say that the type R rack was 3 1/4 as well.
Old Jul 2, 2005 | 08:32 AM
Jon V's Avatar
maybe it's even less than that. Seems like teh R rack should be much better...
I know it is a 15:?:1 ratio...
Old Jul 2, 2005 | 09:00 AM
Setsuna F Seiei's Avatar
Honda-Tech Platinum Member
How about the s2000 spec v variable gear ratio steering (VGS)? 2.25 turns from lock to lock.
Old Jul 2, 2005 | 09:42 AM
Jon V's Avatar
Default Re: Power steering rack or manual rack? (BrokeAssPinoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrokeAssPinoy &raquo;</TD></TR><TR><TD CLASS="quote">How about the s2000 spec v variable gear ratio steering (VGS)? 2.25 turns from lock to lock. </TD></TR></TABLE>
ahve fun moddifing that to fit in a civic. i would rather just bolt the ITR rack in to my Ek...
gotenz90640
Mar 19, 2016 03:57 PM
vtec4lyfe
Jan 8, 2007 07:46 PM
a11mtrhatch
Dec 24, 2004 07:25 AM
Heinvenkin2
Nov 7, 2002 10:22 AM
