Piston slap at startup?
Old Jun 25, 2005 | 10:06 PM
B-B-K's Avatar
Default Piston slap at startup?
I just built me up a lil single slammer. Im running a D16Z6 block, a Y8 head, and ZC pistons. Compression is around 13:1.
Im running this motor just to hold me over while I build my LSV. Im OBD0 running PR3 B16 maps with all kids of fuel added and removed. Motor runs strong. My question is....everytime I start the car is sounds like piston slap. Like the skirts hittin the cylinder wall. Now, Im pretty sure this is not what the sound is, just relating to what it kinda sounds like.
Detonation? Preignition? Only at startup I hear it. I have no idea.....I took timing out from 1300 and under, added fuel...tried everything. I have no idea on what it could be or on how to fix it. I thought since it was such a high compression that it needed some timing taken out at startup....but I tried that and it still makes the noise.
Any ideas?
Thanks
Matt
Old Jun 26, 2005 | 06:44 AM
Chiovnidca's Avatar
Default Re: Piston slap at startup? (B-B-K)
What is the piston to wall clearance? Does it only do it when starting the engine cold? Go away as the engine warms up?
Old Jun 26, 2005 | 08:48 AM
mmuller's Avatar
Mad Scientist
Default Re: Piston slap at startup? (Chiovnidca)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">What is the piston to wall clearance? Does it only do it when starting the engine cold? Go away as the engine warms up?</TD></TR></TABLE>
ditto
Old Jun 26, 2005 | 05:22 PM
B-B-K's Avatar
Default Re: Piston slap at startup? (mmuller)
Hmm, not sure on the clearence. I just threw this motor together while I build my LSV. It does do it when the motor is warm.
Any ideas?
Thanks guys.
Old Jun 27, 2005 | 12:01 AM
UNKNOWN_MEMBER's Avatar
13:1 with pump gas?
t_can
32
Sep 1, 2017 02:24 PM
USDM sI
Engine Management and Tuning
27
Oct 17, 2011 10:50 AM
vtibrazil
Dec 31, 2008 08:01 AM
B20Monster
Apr 17, 2005 06:50 PM
mrx
Feb 2, 2005 09:12 AM
