Did compression test not too sure what to think....
Old Jun 25, 2005 | 09:58 PM
Average Al's Avatar
Default Did compression test not too sure what to think....
Did a compression test today. Warmed car up to operating temp and let it cool down. Pulled the plugs, #4 plug was covered in oil (not around the top, on the electrode it self) the top was clean and the spark plug cylinder was clean, plus i put new seals in a week ago.
#1 was 180 psi
#2 was 160 psi
#3 was 180 psi
# 4 was 180 psi
car does smoke alot, little less now that i put the stock chip in,
smoke right when vtec kicks in, mostly blue.
motor is a b16a2
what should i be thinking of repairing
valve seals
or piston rings?? maybe head gasket
combination
any ideas would help
Old Jun 26, 2005 | 04:55 PM
Average Al's Avatar
up
Old Jun 26, 2005 | 07:15 PM
JDMOrangeFever's Avatar
Default Re: (Average Al)
Do a leak down test..
Old Jun 26, 2005 | 08:00 PM
onepoint6i's Avatar
Default Re: (JDMOrangeFever)
yup leak it..either you rings or your valve seals more than likely its your rings..you change your Pcv valve when you changed the seals? your head gasket has nothing to do with your burning oil.your engine would overheat with a bad Hgasket...
Old Jun 28, 2005 | 10:22 PM
Average Al's Avatar
yeah changed pcv valve just recently
guess i got to do a leak down next
Woogies
Jan 19, 2015 09:30 PM
HDX15
11
May 14, 2013 04:30 AM
bb6guy
Jan 6, 2010 12:59 PM
chickenandpickles
Aug 30, 2005 11:21 PM
743power
Nov 18, 2003 10:28 PM
