Welding Rollcage to Chasis questions
Old Jun 25, 2005 | 07:01 PM
DSRxMilogen's Avatar
Default Welding Rollcage to Chasis questions
ok.. here's the deal.. my friend asked me to weld his cage into his crx for him.. i've welded before and i can get a decent bead going... but i haven't welded a cage to a chasis before... just want to know the correct way of doing things... like if i need to know anything special have it pass inspection or something..
car is a crx, mild steel cage ( I think), i'll be using a Miller MIG welder....
any advice is
thanks
Old Jun 26, 2005 | 06:28 AM
Default Re: Welding Rollcage to Chasis questions (xnorxcalx)
up
Old Jun 26, 2005 | 03:16 PM
blueoval557's Avatar
Well, first you need to verify that it is mild steel. If it is, your good to go. As for passing inspection or not....with NHRA, if all the bars are in the right place, they really cant give you **** about the welds....as long as there not like WHOA bad. If you say yuou can run a decent bead, thats fine. If it is an actual cage kit from a manufacturer, it is more than likely going to be legal. Just look at the rulebook for whatever you want to run, and make sure all the bars meet the specs, and are in the proper place.
After you have done this "homework", you are ready to begin. First thing you need to do is find where each tube will meet the floor. If it is a 4 point cage, there will be 4 points touching the floorboard, if its a 6-point, there will be 6 tubes touching the floorboards...etc.
After you locate where each piece meets the floorboard, you need to cut plates....usually 6x6 inches I believe. You will then weld these to the floorboard itself, and the your base tubes will be welded to these.
After this, it is pretty self-explanatory(sp?). Fit your tubes, notch them if they are not notched....etc.
GOOD LUCK!
Kyle
Old Jun 26, 2005 | 05:39 PM
Default Re: Welding Rollcage to Chasis questions (blueoval557)
dude thanks a lot thats exactly what i needed to hear.. thanks again
Old Jun 26, 2005 | 08:08 PM
No problem. Glad I could help. Feel free to contact me anytime if you need further help. Email is sg7300@softcom.net
Kyle
Old Jun 27, 2005 | 07:43 PM
adictionbass's Avatar
dont know if this will help you any...
https://honda-tech.com/zerothread?id=1280201
Old Jun 28, 2005 | 02:36 AM
RMF
Guest
Posts: n/a
Your problem is ,The car is cad plated .And wire feeds HATE plating.So do heliarcs too.Just take a scotch brite wheel or a super fine sanding wheel.and sand off the paint and plating.And then no problem.
Old Jun 28, 2005 | 08:49 PM
Default Re: Welding Rollcage to Chasis questions (RMF)
thanks RMF for the heads up.. i appreciate it..
racing_reject_001
49
Feb 14, 2007 08:05 AM
No2Pencil
86
Jan 28, 2006 02:04 PM
EFin' Kyle
15
Apr 29, 2005 12:01 PM
dmotoguy
Sep 1, 2003 04:48 AM
Gmedalion
Mar 6, 2002 01:17 PM
