rough idle
Old Jun 25, 2005 | 05:48 PM
EMphaticONE's Avatar
Default rough idle
what does it mean when i start my car and the idle drops (nearly stalling out), then goes up and idles high around 1,200 rpms? this motor is a B16A2
Old Jun 25, 2005 | 06:13 PM
neutron91's Avatar
Default Re: rough idle (EMphaticONE)
check the iac... and make sure the idle speed is correct
Old Jun 25, 2005 | 06:26 PM
zman's Avatar
it means that you need to check your idle air control valve. Its on the back of the intake manifold, pull it off, its 2 12mm bolts, one is longer than the other so remember which one came from where, unplug it and make sure the screen isn't dirty, if it is dirty clean it, let it dry or run compressed air through it, then put it back on and fire her up.
If it still does the same thing unplug it, if it stalls then replace it b/c thats what mine did, just the other day, i replaced it with a spare one i had laying around and viola.
check the voltage at the TPS, it should be .5V closed throttle and 4.5V wide open throttle and the voltage should increase smoothly while opening the throttle.
Iloveyourhonda92
Apr 11, 2015 07:46 PM
manicmechanic
Aug 14, 2011 02:30 PM
1991civicb16
Jul 16, 2011 12:38 AM
protopro88
Apr 8, 2011 03:41 PM
Midori Green
Jan 3, 2007 03:13 PM
