Leaking
alright just put in my new engine, d15b7 blow the other one so just replaced it.. well one of thwe vacumes isnt hooked up to the intake manifold.. but the manifold is pouring out antifreeze and water out the back dont know where though, think its cause one of the vacums isnt plug in. Thanks
yeah dude just look where the coolant is coming from and find the corresponding hose that goes there... it shouldnt be too hard to spot... the hose should be kinked a little and look like it was made to fit... and QUIT driving it like that until you get it fixed or you will be right back where you started... swapping another motor
yeh well i thought i fixed it and tighten the two hoses that fit into the back off the manifold, but thats not it.. im thinking maybe a hole in the manifold or hoses or in wrong spots..
also the vacum line is part of the intake manifold (top right) part of it broke but replacing tommrow, would this be the problem of why the intake manifold is spitting out fluid in the back of it...?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by So_Skilled_01 »</TD></TR><TR><TD CLASS="quote">also the vacum line is part of the intake manifold (top right) part of it broke but replacing tommrow, would this be the problem of why the intake manifold is spitting out fluid in the back of it...?</TD></TR></TABLE>
Vacuum line shouldn't have anything to do with coolant problems. Is it spraying out or leaking?
MaxBoost
Mar 26, 2002 06:08 PM
