Compression=
Old Jun 25, 2005 | 11:55 AM
crix351c's Avatar
Default Compression=
ZER0....cyliner closest to dizzy has none...doesnt even spike on the gauge....possible problems???
Head gasket wouold show sum compression...
Same with piston rings....
Bent Valves???
Old Jun 25, 2005 | 12:05 PM
PURPLETERROR aka BIGMATT's Avatar
Default Re: Compression= (crix351c)
Burnt valve
Old Jun 25, 2005 | 12:09 PM
crix351c's Avatar
Default Re: Compression= (PURPLETERROR)
so.......
Old Jun 25, 2005 | 05:33 PM
crix351c's Avatar
when i pulled the head one of the rocker arms was off lying next to the spring WTF do i do
Old Jun 25, 2005 | 09:04 PM
sanimalp's Avatar
$cat /dev/urandom
i would go with.. get a rebuild. depending on damage.. but.. it might just be cheaper and maybe even easier just to swap engines.. but you never mentioned what you were running. if its a d15, it might be a good time to upgrade to a d16a6 or something. just a thought.. or go mini-me.
Old Jun 26, 2005 | 11:53 AM
crix351c's Avatar
Default Re: Compression= (sanimalp)
DOHC Zc....somebody sabotaged my ****....I pulled the head and there was a BB sitting beetween the valve face and seat....the rocker fell off because the cam wasnt putting pressure on it when the valve didnt shut all the way....NO DAMAGE...i got so lucky nothing happened...the bb never made it into the combustion chamber...everything is finee.....gunna pull the intake mani from head and see if i can see any in there...going to put a thermal intake gasket and maybe some cams.... for being lucky
Vector 25
Nov 20, 2017 07:31 AM
genoaragon869
Feb 28, 2010 09:33 PM
B18C5_VTEC
Oct 8, 2007 02:54 PM
USoMaChine
Apr 10, 2005 03:18 PM
slowazzhatch
13
Jun 1, 2004 08:51 AM
