HELP ASAP-->YS1 Trans into EG which mount?
Old Jun 25, 2005 | 10:06 AM
Calliefornia's Avatar
Default HELP ASAP-->YS1 Trans into EG which mount?
Lets try this again..only posting once
I need to know which top transmission mount do I use to install the YS1(cable) transmission into my 1993 Civic(hydraulic). I've got the conversion braket I have the wrong mount though.
Help ASAP is appreciated as this is my daily driver and my B16 is hanging not mounted in the engine bay.
Old Jun 25, 2005 | 10:33 AM
Dueceification's Avatar
Default Re: HELP ASAP-->YS1 Trans into EG which mount? (Calliefornia)
Sell that tranny and get a hydro you'll be much happier in the end. You could possibly try a 90-93 integra tranny mount dont take my word for it though.
Old Jun 25, 2005 | 10:39 AM
Default Re: HELP ASAP-->YS1 Trans into EG which mount? (93b16hatch)
Thanks 93b16hatch, I tried using the mount that came on the transmission. This engine swap was pulled from a 1992 GS-R.
I know of the Hasport kit but I'm trying to get away with using OEM parts as to save money.
The reason I'm attempting to use the cable tranny is b/c I'm trying to save money and b/c of the gear ratio's.
Old Jun 26, 2005 | 09:43 PM
unknown0001's Avatar
up for a friend in need
Old Jun 26, 2005 | 09:54 PM
DohctorVtec's Avatar
Default Re: HELP ASAP-->YS1 Trans into EG which mount? (Mr.RHTuner)
I would say try Avid because they are pretty cheap but dont because I have the same Tranny (<333 the Gear ratios as well) The mount does not sit flush on the Tranny so I acutally had to cut a piece of the Mount out to make it fit just a LIL bit better but I still had to use spacers oh well umm try the Integra mount as well IMO
Old Jun 27, 2005 | 07:32 AM
So there are no factory mounts that will work?
Old Jun 27, 2005 | 07:53 PM
Default Re: HELP ASAP-->YS1 Trans into EG which mount? (DoctorVtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DoctorVtec &raquo;</TD></TR><TR><TD CLASS="quote">I would say try Avid because they are pretty cheap but dont because I have the same Tranny (&lt;333 the Gear ratios as well) The mount does not sit flush on the Tranny so I acutally had to cut a piece of the Mount out to make it fit just a LIL bit better but I still had to use spacers oh well umm try the Integra mount as well IMO</TD></TR></TABLE>
can you e-mail me any pictures of yours with the spacers you made up, please?
Yeah, that's why I really want to keep the transmission is b/c of the ratios are aggressive.
Is the 1994-2001 Teg mount supposed to work with a YS1 into an EG?
Old Jun 28, 2005 | 05:33 AM
Ill try and get a good picture for you sure
Old Jun 28, 2005 | 05:59 AM
wheels01's Avatar
Didnt your conversion kit come with a mount? My HASPORT kit came with the proper mount. Buying the right mount from Hasport will save you time and money compared to trying vaious mounts to see if the might work.
Old Jun 28, 2005 | 07:14 AM
tgreaves's Avatar
Default Re: HELP ASAP-->YS1 Trans into EG which mount? (wheels01)
Is your tranny the low-geared YS1 jdm cable one(the one that uses the 94-01 integra clutch)? If so you can find a hydro LS tranny case and swap the internals into the hydro case..
Old Jun 28, 2005 | 07:43 AM
Newman's Avatar
New User
Default Re: HELP ASAP-->YS1 Trans into EG which mount? (tgreaves)
Use the HCP EG-18C conversion mount. We used it on our 93 coupe with YS1 LSD tranny for 2 years with zero problems - no dead pedal, nothing. I even tracked the car a few times with it and no problems. The Enjo/Avid ones are junk. They're actually shitty copies of the HCP one but with no R&D so it doesn't work well. Regardless of what people say (go with hydro because it's "better" my ***), it works perfectly fine as an alternative solution. And swapping the guts out and putting them into a hydro casing is not a direct swap. You still need to shim areas to make it fit. PM me for more details.
Old Jun 28, 2005 | 10:20 AM
Default Re: HELP ASAP-->YS1 Trans into EG which mount? (Newman)
oops forgot to type haha heres the pic of my Tranny mount with the spacers as requested
Old Jun 28, 2005 | 10:31 AM
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Newman &raquo;</TD></TR><TR><TD CLASS="quote">And swapping the guts out and putting them into a hydro casing is not a direct swap. You still need to shim areas to make it fit.</TD></TR></TABLE>
What shimming needs to be done? I swapped over a YS1's internals last night into a LS case and everything seems to be perfect with it..
Old Jun 28, 2005 | 04:00 PM
Thanks for the pics DoctorVtec and Newman. I im'd you Newman. I just want what is least hassle and most reliable.
Is it possible to just change the bell housing on the YS1 to a hydro bell housing?
Modified by Calliefornia at 6:21 PM 6/28/2005
Old Jun 29, 2005 | 05:29 AM
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Calliefornia &raquo;</TD></TR><TR><TD CLASS="quote">Is it possible to just change the bell housing on the YS1 to a hydro bell housing? </TD></TR></TABLE>
The bell housing is part of the tranny case so no, you cant just change that..
Old Jun 29, 2005 | 11:06 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves &raquo;</TD></TR><TR><TD CLASS="quote">
The bell housing is part of the tranny case so no, you cant just change that..</TD></TR></TABLE>
Thanks...that would have been too easy.
Old Jun 29, 2005 | 11:10 AM
tgreaves's Avatar
Thanks...that would have been too easy. </TD></TR></TABLE>
That would be kinda easy.. You can do that on mullet trannies but not Hondas..
Old Jul 13, 2005 | 08:30 AM
Thanks Newman and JDMshit.com.
UPS
The HCP top tranny mount is installed...I just need some more direction for the placement of the other pieces.
Old Jul 16, 2005 | 04:14 AM
Newman, can you please tell me the tips and tricks to installing the hydro conversion now. I've e-mailed you at sales@jdmshit.com and the picture you keep sending me is NO help. I need verbal help if you don't have any decent pictures. You seemed confident that these parts were easily installed vs other kits however they don't seem to line up anywhere.
Do I have to modify these parts or are they direct installations???
Old Jul 16, 2005 | 06:54 AM
Agent STFU's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93b16hatch &raquo;</TD></TR><TR><TD CLASS="quote">Sell that tranny and get a hydro you'll be much happier in the end.</TD></TR></TABLE>
Negatory on that one.
YS1
Old Jul 16, 2005 | 09:15 AM
Default Re: HELP ASAP-->YS1 Trans into EG which mount? (Retarded chicks are SEXY)
Oh I feel you on that one. But he could get a ITR tranny And have good ratios and LSD But in his case it's not cost effective. From my own experiences with motor mounts I would take HCP over any other any day (well except for Hasport). Try the HCP kit and I recomend buying from JDMshit.com / Newman good people
Old Jul 16, 2005 | 10:55 AM
Ya, I agree Newman and JDMshit are good to buy from, I'm just in need of getting the HCP cable/hyrdo conversion to work and the instructions...are well they're aren't any. Just a really really poor picture that you can only see the clutch slave. If anyone else knows how to install the HCP cable/hydro clutch conversion kit please chime in.
Thanks
Old Jul 16, 2005 | 10:59 AM
Agent STFU's Avatar
Doesn't YS1 have LSD too?
Old Jul 17, 2005 | 07:23 AM
Not all YS1 are LSD but you can get an OEM LSD YS1.
Hanmin
Jun 16, 2008 05:26 PM
atleast-3
Sep 23, 2007 12:07 AM
be18see1
Jul 31, 2007 06:24 AM
KickStart2323
Mar 8, 2007 06:23 AM
Calliefornia
Jun 25, 2005 08:10 AM
