Help please!!!!!!!!!!!!!!!!!!!!!!!!!!!!! on crx/b16 stalling out
All right guys i need some much needed help..... I swapped a b16 into my crx about two years ago i took it out last year before winter to put an integra tranny in. I finally got it back together just about a month ago and have a problems... the first day i got it back together i drove it for probably 20 miles no problems except loose alt. belt. brought it back home. go to drive it the next day and stalls out around the block had to wait 20 mins or so started back up stalls out again right as i get home and does it every time.... i can let it sit and idle fine rev it up wont stall soon as i go to drive it stalls out. when it stalled out the other day i sprayed starting fluid in the intake fired up and shut right back off. so im thinking maybe a fuel problem.. heres what ive changed, fuel pump walbro 255, fuel filter, main relay, plugs and wires, swapped from my buddies car, fuel pressure reg., dist. ,map sensor, and computer. i put h23 injectors in as well. There are no engine lights or codes on the ecu. Now could it be the tank not vented right, i took the gas cap off to see but not sure if that would work. i am stumped please help if possible thanks
1st question: Do you have gas?
Check ALL your connections. Even the obvious ones. I'm sure you'll feel pretty stupid about the car stalling all the time because you grounded a wire somewhere. Remove the rear compartment cover and make you didn't pinch a line somewhere. Get a lift to AutoZone or AdvanceAutoParts and get your battery and alternator tested for free.
yah it has full tank of gas... the alt. charges fine...... i checked all the grounds a few times because that is what i was told might be wrong i have been going over this for the last two weeks i dont have a clue any more!!!!
Oldboyoh
Sep 21, 2011 10:12 PM
Friedenreich686
Apr 12, 2005 08:30 PM
