Opinion on Skunk2 Type3 Cams?
Old Feb 12, 2002 | 09:58 PM
TypeR582's Avatar
Default Opinion on Skunk2 Type3 Cams?
What do u guys think about the skunk2 type3 cams. U think they are worth it? Local aftermarket shops say stock itr valve springs can handle the cams. Is it true?
Old Feb 12, 2002 | 10:32 PM
xjohnx's Avatar
Default Re: Opinion on Skunk2 Type3 Cams? (TypeR582)
I wouldn't run stock springs on skunk stage 2's, much less the 3's, you'll need an upgraded valvetrain.
Old Feb 12, 2002 | 11:59 PM
Type R's Avatar
Default Re: Opinion on Skunk2 Type3 Cams? (xjohnx)
yup because to get the most hp out of those type 3s youll need to rev high and will need a new valvetrain to do so. Importreview is testing the 3s right now so look out for a dyno graph in the next couple of days.
Old Feb 13, 2002 | 03:18 AM
speedymon's Avatar
Default Re: Opinion on Skunk2 Type3 Cams? (Type R)
So would a ITR outer and portflow inners work? Or all aftermarket springs?
Old Feb 13, 2002 | 07:37 AM
TypeR582's Avatar
what if i am only reving at 8400 do i still need to change my valvetrain and if i dont change it will i damage my engine.
Old Feb 13, 2002 | 07:43 AM
RyanR's Avatar
Yes, you still need to upgrade your valvetrain. The stage 3 cams have a lot of lift which means you will probably get spring bind with the stock springs.
Old Feb 13, 2002 | 08:10 AM
BoM's Avatar
BoM
Default Re: Opinion on Skunk2 Type3 Cams? (RyanR)
valvesprings are also dependent upon the lift of the cams, not just the rpms.
stick with stage 2 if your going that route.
Old Feb 13, 2002 | 08:21 AM
azn98R's Avatar
Default Re: Opinion on Skunk2 Type3 Cams? (BoM)
I would think it is worth it if you would upgrade your valvetrain, specially when your planning to do cam work (stage 3). Not worth blowing your engine cause you wanna cut corners, couple hundreds is not too much. Just my 2 cents.....
Old Feb 13, 2002 | 10:05 AM
AllMotorMadness's Avatar
JEFF SHOULD HAVE RESULTS SOMETIME THIS WEEK
sol_1
Nov 11, 2007 10:56 AM
8Si8
14
Jun 30, 2005 03:48 AM
jaystation
May 10, 2005 04:20 PM
FusionEg6
Sep 11, 2003 10:23 PM
