recharing battery
Old Jun 25, 2005 | 02:54 AM
budget's Avatar
Default recharing battery
when autozone "re-charges" your battery does that mean its like brand new again? or does that just get you a little more life out of the battery and you should replace it soon?
the battery is going on 5 years and interior lights are starting to look dim
Old Jun 25, 2005 | 03:28 AM
Sticky Tires's Avatar
* B A N N E D *
Default Re: recharing battery (Straight Flush)
Recharging a battery is recharging a battery. It juices it back up. Since your battery is 5 years old, I would just replace it.
But if you're cheap, just get it recharged.
Old Jun 25, 2005 | 03:45 AM
budget's Avatar
Default Re: recharing battery (Sticky Tires)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sticky Tires &raquo;</TD></TR><TR><TD CLASS="quote">Recharging a battery is recharging a battery. It juices it back up. Since your battery is 5 years old, I would just replace it.
But if you're cheap, just get it recharged. </TD></TR></TABLE>
what #'s should i look for when the are testing it?
Old Jun 25, 2005 | 03:56 AM
* B A N N E D *
You got PM.
Old Jun 25, 2005 | 09:33 PM
PrettyLude's Avatar
should get 12 volts with the battery, and 14 volts with the engine started, if you are not getting 14 volts when your car is started, your alternator is not charging
emegge
Aug 10, 2006 04:07 PM
buzlink
16
Dec 13, 2002 12:25 AM
