no vt@akk j00 what could be the reason .....
i have done just about everithing ... to get this **** runing ... 93 cx hb with 95 gsr ..is not hitting vtec ......i wire up the vtec pressure switch , vtec solenoid valve , i wire the ect sensor to my ecu ,, ....
now my question is would vtec hit even if I dont have the o2 sensor ? connected to the ecu
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGSR »</TD></TR><TR><TD CLASS="quote">i have done just about everithing ... to get this **** runing ... 93 cx hb with 95 gsr ..is not hitting vtec ......i wire up the vtec pressure switch , vtec solenoid valve , i wire the ect sensor to my ecu ,, ....
now my question is would vtec hit even if I dont have the o2 sensor ? connected to the ecu </TD></TR></TABLE>
What is the ect sensor and what ecu are you running?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dragline »</TD></TR><TR><TD CLASS="quote">What is the ect sensor and what ecu are you running?</TD></TR></TABLE>
engine colant temp.... and i use the jdmp72 ecu obd1
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dragline »</TD></TR><TR><TD CLASS="quote">why did you have to wire the ect sensor to the ecu wasn't there one already?</TD></TR></TABLE>
i had to it was disconected / cutted and in order to run vtec ect and vss sensor's need to be working
racetek82
Jan 26, 2005 10:16 AM
