F23A4 Oil Problem
Old Jun 24, 2005 | 08:46 PM
THE BALANCE's Avatar
Default F23A4 Oil Problem
Hey Ive been searching and trying to find out the problem of this and needed some help so I'M turning to you guys.
My 01 F23A4 is blowing oil through the breather hose and the pvc hose and the pvc valve is new. What is causing this problem?
Thanks in advance
Jimmy
Old Jun 27, 2005 | 03:50 AM
JimBlake's Avatar
Default Re: F23A4 Oil Problem (THE BALANCE)
Maybe it's blowby... How's your compression?
Old Jun 28, 2005 | 02:41 PM
Default Re: F23A4 Oil Problem (JimBlake)
I'm not sure on the compression problem but I disconected the PVC valve from the intake manifold and caped the manifold becasue it was sucking oil.
Old Jun 28, 2005 | 03:00 PM
as_fast_as_u's Avatar
very common if you have oil leak through your head(valves, seals, etc) thats what its sounds like. I'm almost 100%
Old Jul 1, 2005 | 01:39 PM
so if it was say my valves would a valve adjustment help this problem
Old Jul 1, 2005 | 02:54 PM
goowakjai
Guest
Posts: n/a
Default Re: (THE BALANCE)
yea, if oil is blowing through ur PCV valve, its not the PCV thats ******* up, its actually working perfectly fine...ur problem is u need find where oil is leaking through, like said above, u probably have excess blow by(air escaping from combustion chamber into crankcase...so maybe ur piston rings arent sealing like they shud be
Old Jul 1, 2005 | 09:13 PM
adjusting valves isnt going to do much, but maybe get rid of noise... like stated above, you could have cracked ringlands, that are sucking oil through rings into combustion chamber and gunking up valves, leaving them open to oil flow into top of your head and into valve cover, blah blah...
basically, take it easy on the motor, make it last as long as you can...but eventually you'll have to have it replaced...IT sux, but it is what it is
AllMotorMark
Apr 23, 2020 08:30 PM
420honda420
Feb 9, 2015 08:19 AM
Set O' Nines
Oct 30, 2012 07:49 PM
Hdeucedeuce
Jul 23, 2011 02:19 PM
Takumi Fujiwara
Jan 31, 2006 07:52 AM
