life of battery
Old Jun 24, 2005 | 08:44 PM
twenty's Avatar
Default life of battery
how often do you have to replace the battery? ive had the same battery for 4 years that came stock when i bought the car new in 2001.
what are some common signs of the battery going out or needing a replacement? can you take it to an autozone or something for them to check and charge it or should i just buy a new one?
Old Jun 24, 2005 | 08:50 PM
2 Loe 4 Fat Hoes's Avatar
Default Re: life of battery (standard staples)
yes you could take it to auto zone to get it check if your car struggles to start that could be a sign
Old Jun 24, 2005 | 08:54 PM
coupon's Avatar
Default Re: life of battery (2 Loe 4 Fat Hoes)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2 Loe 4 Fat Hoes &raquo;</TD></TR><TR><TD CLASS="quote">yes you could take it to auto zone to get it check if your car struggles to start that could be a sign</TD></TR></TABLE>
so the battery light doesnt have to be on when its on its way out?
Old Jun 24, 2005 | 08:58 PM
.:Swig:.'s Avatar
Default Re: life of battery (fifth street)
i replace mine every 5 years
Old Jun 24, 2005 | 09:14 PM
tele's Avatar
This is hardly the norm, but I just replaced the battery in my 95 Coupe EX this week for the very first time. Just shy of 10 yrs. No warning, just gave up the ghost the other day.
With 70K miles, my original Potenza RE92 tires still have good tread on them and have worn very evenly. I think I'm going to replace them now though, due to age. Also on the original brake pads, etc.
Old Jun 24, 2005 | 10:15 PM
twenty's Avatar
Default Re: life of battery (tele)
what do i look for when im shopping for a battery? brand,type,volts?
Old Jun 24, 2005 | 11:14 PM
tele's Avatar
Most relevant is probably cold cranking amps and the warranty. Cars are 12V DC. You don't need to do much homework, as fitment guides pretty much simply point to the single (usually) model that is applicable from a given battery maker or dealer.
Most Honda batts are sourced from Interstate or Delphi, depending on the dealer. I did my homework last week, and after calling around and getting good input from independent dealers of both, I was directed to Costco for their house brand (which may be Interstate sourced). Anyway, for my Civic EX, at $35 it was about half price of the best deals I found elsewhere, and the warranty is excellent. Was a direct fit, started right up, good to go.
Modified by tele at 12:18 AM 6/27/2005
Old Jun 24, 2005 | 11:21 PM
coupon's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tele &raquo;</TD></TR><TR><TD CLASS="quote">Most relevant is probably cold cranking amps and the warranty. Cars are 12V DC. You don't need to do much homework, as fitment guides pretty much simply point to the single (usually) model that is applicable from a given battery maker or dealer.
Most Honda batts are sourced from Interstate or Delphi, depending on the dealer. I did my homework last week, and after calling around and getting good input from independent dealers of both, I was directed to Costco for their house brand (which may be Interstate sourced). Anyway, for my Civic EX, at $35 it was about half price of the best deals I found elsewhere, and the warranty is excellent. Was a direct fit, started right up, good to go.</TD></TR></TABLE>
whats a good # to look for on Cold Cranking Amps?
Old Jun 25, 2005 | 12:09 AM
sam385's Avatar
Default Re: life of battery (00mofo)
a 'good ' battery will test over 12 volts with a DC voltmeter with the car off.... bad batteries or those going bad will test below 12 volts.
battery life depends upon the environment of where you live too.
Old Jun 25, 2005 | 01:19 AM
coupon's Avatar
Default Re: life of battery (sam385)
what happens if you buy a battery that doesnt have enough cca?
Old Jun 25, 2005 | 03:31 AM
pdiggitydogg's Avatar
The car will be hard to start.
I just replaced my original battery, from 97, last week. The new one is a cheap pos, because its all they had (its got like 450cca...)
Old Jun 25, 2005 | 03:51 AM
hc99si1's Avatar
I've had my standard battery in the car from new 6 years now. No problems yet.
Integ808
Oct 16, 2008 02:57 AM
tigueremalo
May 23, 2006 10:55 AM
DC2*Integra
Oct 16, 2005 06:33 AM
fanta!
Jun 24, 2005 11:39 PM
horror
Oct 25, 2002 11:01 AM
