dyno vid and pics. D16Y8
Old Jun 24, 2005 | 08:37 PM
cua0's Avatar
Default dyno vid and pics. D16Y8
dyno sheet,
here's a video.
http://members.shaw.ca/barcher/BrentsDyno.wmv
not the best video, but hey its my first time making a video.
car is a 96 civic Si (canadian)
i built the setup, the intercooler core i had was too big so i ended up ghetto mounting a 2g dsm sidemount i had kicking around.
its half diy and half professionally built. heh.
Old Jun 24, 2005 | 08:51 PM
Sinner's Avatar
i put my intercooler in the same place... it was more of a air-heater when i had it there. I had the same DSM SMIC also. still thats nice power on a mustang dyno
Nick
Old Jun 24, 2005 | 08:53 PM
2000psi's Avatar
From: We Cant Stop Here This Is Bat Country, So CaL, USDM
Default Re: dyno vid and pics. D16Y8 (cua0)
Nice numbers! I'm assuming stock internals? As long as that IC isn't permanent you look good to go.
Old Jun 24, 2005 | 09:29 PM
YiNYaNg's Avatar
HMT
Old Jun 25, 2005 | 12:16 AM
cua0's Avatar
i plan on swapping the intercooler out asap.
like i said the core i was building end tanks for was too big.
i'm a welder by trade so i dunno if it classifies as hmt really, other than the ghetto intercooler placement.
Old Jun 25, 2005 | 06:43 AM
1boostedcivic's Avatar
Default Re: (cua0)
I guess ill be the first to ask: how much psi were u running??
Old Jun 25, 2005 | 07:40 AM
TurboGoKart's Avatar
Default Re: (1boostedcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1boostedcivic &raquo;</TD></TR><TR><TD CLASS="quote">I guess ill be the first to ask: how much psi were u running??</TD></TR></TABLE>
Old Jun 25, 2005 | 09:18 AM
jyjck5's Avatar
Nice numbers man. I dont like the smic thought. Anyway cool cool.
Old Jun 25, 2005 | 11:24 AM
dornon13's Avatar
Default Re: (jyjck5)
on the dyno sheet why does it say 96 civic SI?
Old Jun 25, 2005 | 11:39 AM
cua0's Avatar
yup because i'm canadian. the 96-00 civic Si here is the same as the EX in the states.
that power was put down at 10psi
stock internals, so i didn't want to pop the motor by going any higher
Modified by cua0 at 7:05 PM 6/25/2005
Old Jun 25, 2005 | 12:24 PM
dornon13's Avatar
Default Re: (cua0)
thats cool learn something new every day. good numbers
Old Jun 25, 2005 | 12:47 PM
PHiZ's Avatar
Default Re: (dornon13)
Hrm, Tq numbers seem a little off.
Here is a good repository of Turbo D dynos to compare against:
http://turbod16.com/viewtopic.php?t=4140
-PHiZ
Old Jun 25, 2005 | 02:15 PM
cua0's Avatar
my torque numbers are low compared to those guys
not by much though.
Old Jun 25, 2005 | 02:27 PM
MikeD718's Avatar
Default Re: (cua0)
what are you using for fuel management?
Old Jun 25, 2005 | 04:48 PM
cua0's Avatar
Hondata s200
p28 ecu.
Old Jun 25, 2005 | 06:42 PM
Steve-'s Avatar
Default Re: (cua0)
was this tuned or un-tuned? i'm guessign un-tuned?
Old Jun 25, 2005 | 07:39 PM
Snail Tuning's Avatar
Default Re: (PHiZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PHiZ &raquo;</TD></TR><TR><TD CLASS="quote">Hrm, Tq numbers seem a little off.</TD></TR></TABLE>
i think that could be due to heat soak. considering it looks like a stock radiator, SMIC under the hood, and an equal length manifold thats unwraped, i bet those underhood temps are really really high. good to see you want to change that intercooler, i would also look into a dual core radiator, or a delsol vtec radiator to get alittle more volume of heat transfer. otherwise everything looks good, and great numbers. i made 184hp, and 154tq untuned, at 9lbs, with bad heat soak. tuned, it vented the hood, and got a bigger radiator, and the car felt 10x's faster.
Old Jun 25, 2005 | 07:51 PM
cua0's Avatar
that was after tuning. but we tuned it very conservatively because of the stock internals.
the d internals like to let go above 220, so i wanted to keep it around 200, i exceeded my goals, so i'm happy.
i also didn't push it into the redline too much, but as you can see from the graph the numbers were still climbing when i let off.
yeah, it was majorly heatsoaked, i was considering putting ice on top of the intercooler for the tuning but forgot to grab some on my way in.
Old Jun 26, 2005 | 11:20 PM
Timmay's Avatar
Default Re: (cua0)
sickness brent, FMIC and more fine tuning , go for 230-240 whp
Old Jun 27, 2005 | 12:35 AM
NumberB's Avatar
Default Re: (Timmay)
from what i can tell the lower o2 is a wideband correct? how far downstream is that? plx told me they reccomend atleast 2 feet downstream for placing my wideband because of temp issues, have you had any probs with the wbo2 sensor/how long have you been running it?
Old Jun 27, 2005 | 02:29 AM
Calvinator's Avatar
Default Re: (milb16a)
What kind of turbo are you running?
Old Jun 27, 2005 | 12:52 PM
cua0's Avatar
second o2 is a wideband yes, its about 15 or 16" downstream. no problems yet. i couldn't really go any farther down without worrying about it.
the turbo is a T3/T04E .48A/R / 60 trim
Old Jun 27, 2005 | 01:05 PM
SOHC_MShue's Avatar
When do you hit full boost with that turbo? Thats some high power on a mustang dyno.
Old Jun 27, 2005 | 01:14 PM
EJ1 wilcox's Avatar
Default Re: dyno vid and pics. D16Y8 (SOHC_MShue)
That's some good power
Good job.
Old Jun 27, 2005 | 01:18 PM
Dr. D-Series's Avatar
I had same ic in same spot.
I took it off. And it was faster haha.
Now I have it front mounted and way better.
BTW sweet setup.
