GSR, ITR, SI, and aftermarket stuff
Old Feb 12, 2002 | 08:52 PM
TurboT's Avatar
Default GSR, ITR, SI, and aftermarket stuff
-Toda Spec C cams and Toda valve spring set
2 cams, 16 inner springs, 16 outter springs - $1050 shipped
-Pair of STR race cam gears, silver in color - $150
-Kaaz GSR and ITR differential, 60mm bearings already pressed onto
the differential. used for 5k miles - make offer
ITR stock parts:
-intake camshaft, 20k miles - $make offer
GSR stock parts:
-94-00 Integra engine lower mount, part #50841-ST7-Z00 - $20
-98 GSR b18c1 stock spark plug wire set - $40
-98 Acura Integra stock springs - $40
-94-00 Integra A/C compressor with clutch assembly - $50
-94-00 Integra condensor with mounting rail - $50
-94-00 Integra dryer with bracket and bolts - $20
-94-00 Integra A/C fan - $30
-98 Integra steering wheel, leather wrapped, airbag, with cruise control equipment (switch, harness, control module, control unit, cable, pedal hinge) - $600
-98 Integra front bumper amber turn lights - $20
Civic Si stock parts:
-00 si b16a2 head bolts - $30
-00 Si b16a2 stock cams with stock gears - $75
Electronics:
-DEI remote window roll up and roll down control system - $75
-Integra Type-R stock radio with security code (lights up amber) - $125
Others:
-Sparco footrest, for BMWs, anodized red, brand new - $25
-Reinforced hood locking system - $30
Old Feb 12, 2002 | 08:55 PM
TurboT's Avatar
Default Re: GSR, ITR, SI, and aftermarket stuff (TurboT)
also possibly forsale...
98-01 Integra Wings West Complete Kit...
side skirts, front lip, and rear lip...
the rear lip needs work... it was melted due to backfiring...
anyone intersted?
i need a 98-01 ITR factory lip...
Old Feb 12, 2002 | 11:30 PM
hfracer420's Avatar
will the 01 b16a2 cams and gears fit on a 92 ls motor? any performance gain?
Old Feb 13, 2002 | 03:36 AM
tecnic1's Avatar
would you be interested in seperating the springs from the cams?
Old Feb 13, 2002 | 07:29 AM
TurboT's Avatar
Default Re: GSR, ITR, SI, and aftermarket stuff (tecnic1)
the cams won't work in the b18b nonvtec motor...
sorry, selling them as a package...
Old Feb 13, 2002 | 09:07 AM
tecnic1's Avatar
hit me up on IM if you change your mind...I'm CIH for the springs.
Old Feb 13, 2002 | 11:59 AM
TurboT's Avatar
ttt
Old Feb 13, 2002 | 01:33 PM
GSRfoedoe's Avatar
i might be interested in da Kaaz dependin on price and condition. email me wit a price.
Old Feb 13, 2002 | 05:49 PM
TurboT's Avatar
Default Re: GSR, ITR, SI, and aftermarket stuff (GSRfoedoe)
e-mail please
Old Feb 13, 2002 | 07:32 PM
TurboT's Avatar
ttt
Old Feb 14, 2002 | 07:11 AM
TurboT's Avatar
Old Feb 14, 2002 | 11:07 PM
TurboT's Avatar
Old Feb 14, 2002 | 11:51 PM
TurboT's Avatar
ok guys,
add this to the list...
Brand new Clutchmaster's aluminum flywheel anodized blue...
it's aluminum with a replaceable friction plate made of steel...
all hardware is included... again brand spanking new...
Brand new Exedy race organic clutch kit...
includes pressure plate, new disk, throw out bearing, pilot bearing, instructions, clutch alignment tool...
again brand new!
if local to chicago...
i can install the clutch, flywheel, and KAAZ for a good deal!
let me know
Old Feb 15, 2002 | 07:47 AM
TurboT's Avatar
common people!
Old Feb 15, 2002 | 10:05 AM
redteg1's Avatar
so its the whole toda C set basically for 1050...not bad at all...how woud i get em
Old Feb 15, 2002 | 03:25 PM
TurboT's Avatar
Default Re: GSR, ITR, SI, and aftermarket stuff (redteg1)
shipping
Old Feb 15, 2002 | 05:32 PM
gamby's Avatar
300 bucks for the ITR diff.
[edit] gamby1@mediaone.net if 'yes'
[Modified by gamby, 6:32 PM 2/15/2002]
Old Feb 15, 2002 | 07:56 PM
TurboT's Avatar
Default Re: GSR, ITR, SI, and aftermarket stuff (gamby)
ITR diff?
just kaaz which fits GSR and ITR trannies
Old Feb 16, 2002 | 10:08 PM
TurboT's Avatar
Old Feb 16, 2002 | 10:43 PM
C4wrx's Avatar
how much do you want for the clutch?
Old Feb 16, 2002 | 10:51 PM
sk8phaze's Avatar
Would the B16a2 head bolts fit a 91-92 b16a JDM head off a 5 series block?
Old Feb 17, 2002 | 09:54 AM
TurboT's Avatar
Default Re: GSR, ITR, SI, and aftermarket stuff (sk8phaze)
$225 shipped for the clutch...
not sure if the headbolts fit...
but, i think they might since the block height and head are the same
Old Feb 17, 2002 | 02:06 PM
2001silvergsr's Avatar
How much for flywheel?
Old Feb 17, 2002 | 09:35 PM
TurboT's Avatar
Default Re: GSR, ITR, SI, and aftermarket stuff (2001silvergsr)
$275 shipped for the flywheel
Old Feb 18, 2002 | 07:46 AM
TurboT's Avatar
NationsMostWanted
Nov 7, 2007 12:32 AM
TurboT
Feb 26, 2002 03:19 PM
TurboT
Jan 20, 2002 05:00 PM
TurboT
Dec 12, 2001 07:56 PM
