NEED HELP ASAP!! Can't OEM wheel off!!
Old Jun 24, 2005 | 07:48 PM
{Powered by VIII}'s Avatar
Default NEED HELP ASAP!! Can't OEM wheel off!!
there are those 2 plastic pieces on each side of the wheel you need to take off to get the torx bolts, i got the one off on the left side but cant get the bigger one off on the right side. i would take pictures but my computer that i load pictures on has a virus. please if anyone knows what the hell im talkin about please help. i've searched and i cant find anything on how to get this little piece of **** off. i would of broken it off by now but i want to keep all my oem parts in good condition. PLEASE HELP!!!!
Old Jun 24, 2005 | 07:50 PM
B2FiNiTY's Avatar
Default Re: NEED HELP ASAP!! Can't OEM wheel off!! ({Powered by R})
Most of the time, it gets broken when removed.
Old Jun 24, 2005 | 07:51 PM
1GreyTeg's Avatar
what OEM wheel?
what torx?
Flux's Avatar
Are you taking the wheel off or the rotor or what? To take the wheel off remove the lugs - if it seems stuck it may have rusted on a bit, this is somewhat normal. Just knee one edge of the tire and the wheel should pop off.
B2FiNiTY's Avatar
Default Re: NEED HELP ASAP!! Can't OEM wheel off!! (Flux)
He is talking about the oem steering wheel
Old Jun 24, 2005 | 07:52 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flux &raquo;</TD></TR><TR><TD CLASS="quote">Are you taking the wheel off or the rotor or what? To take the wheel off remove the lugs - if it seems stuck it may have rusted on a bit, this is somewhat normal. Just knee one edge of the tire and the wheel should pop off.</TD></TR></TABLE>
hahah no im talkin about my oem itr steering wheel, theres two pieces of plastic on each side and i cant get the one on the right side off.
Default Re: NEED HELP ASAP!! Can't OEM wheel off!! (B2FiNiTY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">Most of the time, it gets broken when removed. </TD></TR></TABLE>
so should i just give up and break it off, i already cracked it
Old Jun 24, 2005 | 08:01 PM
anyone?????????
Old Jun 24, 2005 | 08:02 PM
1GreyTeg's Avatar
probably woulda been helpful if you mentioned steering wheel.
Old Jun 24, 2005 | 08:07 PM
Flux's Avatar
Default Re: NEED HELP ASAP!! Can't OEM wheel off!! (1GreyTeg)
&lt;--- shrugs
Old Jun 24, 2005 | 08:16 PM
B2FiNiTY's Avatar
Yeah, I've done a lot of steering wheels. On some cars they came off easy while on others I had to break it off.
Old Jun 24, 2005 | 08:25 PM
KOALA YUMMIES's Avatar
If they always break you're not using the right torx bit. Its that simple, I've never broken them, just find the right bit.
I find it amazing you know they're torx bolts, yet you're confused as to what to use to remove them? Torx bits/sockets/screwdrivers!
Old Jun 24, 2005 | 08:29 PM
fullraceacura's Avatar
Default Re: NEED HELP ASAP!! Can't OEM wheel off!! (KOALA YUMMIES)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KOALA YUMMIES &raquo;</TD></TR><TR><TD CLASS="quote">If they always break you're not using the right torx bit. Its that simple, I've never broken them, just find the right bit.
I find it amazing you know they're torx bolts, yet you're confused as to what to use to remove them? Torx bits/sockets/screwdrivers! </TD></TR></TABLE>
Old Jun 24, 2005 | 08:53 PM
Default Re: NEED HELP ASAP!! Can't OEM wheel off!! (itr#xxxxlives)
i was talking about the plastic pieces you have to take off to get to the torx screws. i got it off finally, i just gave it muscle and broke it off.
Old Jun 24, 2005 | 10:22 PM
Ohh, man you had trouble with those!?!?!
Kryptonite
Mar 31, 2008 11:22 PM
akunamatta
Jul 5, 2007 04:05 PM
wardseg6
Jun 22, 2007 01:24 AM
amy
Mar 7, 2007 06:10 AM
Edulerp
Aug 27, 2005 02:21 PM
