Rear Wiper HELP PLEASE
Ok I know this has been posted a few times but I need help. Im in the middle of removing my rear wiper and ive taken off the inner plastic linning in the trunk to take off the motor. I unscrewed all the motor bolts. I also took off the wiper arm itelse. Now all that remains is a brass looking bolt sticking through the glass with a brass looking nut around it, and its holding the motor (dangling) in place. I can't figure out how to take off the rest.... HELP ME PLEASE!!!
When I try turning that nut, the whole motor below turns too, and it seems like nothing is happening, even when holding the motor to prevent it from turning so I can actually loosen the nut.....
[Modified by JasonNagra, 5:57 AM 2/13/2002]
I WAS stuck exactly at that ponit in the pic. But I got it off, it just took my friend to hold the motor and me to turn the wrench in opposite directions, DAMN that was a bitch. THANK YOU EVERYONE WHO TRIED TO HELP! Thanks, Jason.
heh, we undid the nut before unbolting the motor, so no problems were encountered....glad you got it figured out! have fun getting the hatch lining back in
the motor is about 2-3 lbs.
[Modified by Saga, 5:33 AM 2/13/2002]
Thanks
I guess it's not really worth taking it out to save like 4-5 lbs. (including wiper and stuff).
Thanks
Thanks
car looks much better without it, you don't have to worry about it flying up at speed, visibility is improved to the rear a bit, and you free up a switch and motor that you could turn into an oil slick
Just lay down some RainX and you'll never miss it.
But if you remove the motor on the front wipers as well then you will remove over 10 lbs. and that will give you the ultimate "cleaner" look eh?
I hate wiper arms...
what do you guys use to cover up the hole after the wiper and motor are off? I was thinking about it but wanted to make sure I have somthing to cover the hole after.
