99 Prelude Radiator Fan Not Coming On - Help!!!
Old Jun 24, 2005 | 06:55 PM
JDMCivicEF9's Avatar
Default 99 Prelude Radiator Fan Not Coming On - Help!!!
I need help with this situation. My friend drives a 99 Prelude and his radiator fan doesn't come on. The only time that it comes on is that when you turn on the A/C. If its a sensor where is it at? This problem has made us just scratch our head for an hour already!
Old Jun 24, 2005 | 09:03 PM
Fongman's Avatar
Default Re: 99 Prelude Radiator Fan Not Coming On - Help!!! (JDMCivicEF9)
Your coolant sensor for the fan might be dead. I think it is under the dis. one is for ecm and one is for the gauage. if you are not sure just buy one or ask the parts store for one and they will show you. then you will know what it looks like.
its cheap you might just want to change it.
Old Jun 24, 2005 | 10:40 PM
shreker's Avatar
what i did was just make it where the fans are on all the time.its better cause your car runs cooler!no doubt
Old Jun 25, 2005 | 11:45 AM
Fongman's Avatar
Default Re: (shreker)
I'm pretty sure thats bad for the car.
Old Jun 25, 2005 | 09:30 PM
PrettyLude's Avatar
Default Re: (Fongman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fongman &raquo;</TD></TR><TR><TD CLASS="quote">I'm pretty sure thats bad for the car.</TD></TR></TABLE>
that's not necessarily true
i would definately try to figure out, why your cooling fans are not coming on? maybe you have a bad thermo switch, that's on the thermostat housing
Old Jun 27, 2005 | 08:01 PM
shreker's Avatar
all you have to do is take the clip off the sensor, run a wire from one side of the sensor to the other side and then they will stay on constantly.believe me your car will run alot cooler!
Old Jun 27, 2005 | 08:49 PM
brolli's Avatar
well its not going to hurt your car but you will ruin the fan motor pretty quickly. are there two fans, one for ac, and one for engine cooling or just one?
Old Jun 27, 2005 | 08:52 PM
brolli's Avatar
Default Re: (brolli)
not only does it make it run cooler but it makes it warm up a lot slower which isnt good obviously and youll use more gas since it takes longer to get to operating temp.
305S0L
May 13, 2008 12:43 PM
greenli0n25
Jun 21, 2003 07:16 PM
Pinpid
Sep 22, 2002 10:41 AM
