going to the track...
Good fluid, if you're in a pinch, try a local ford dealer, many car ford HP fluid in stock. Get better front brake pads too if you can, you can do without them but you'll be glad you got them if you're on track for a while... IM CarbotechAndy on this board for a good deal on Carbotech panther pads, tell him your needs and he can hook you up.
EDIT: You are talking about a road course, right? A drag strip isn't a track, it's a strip
[Modified by Aleph, 1:05 AM 2/13/2002]
Fluids...very good idea. Just make sure you put in a DOT3 or DOT4 type. Btw both flavors are compatible with each other (according to the manual). Watch out for DOT5 however, which doesn't work well with the OE rubber components in the brake system, and it is more hydroscopic, requiring more bleeding.
What everyone else said and........
Tyres are a quick upgrade. Try Yokohama A032R's or Falken Azinas.
Also Spoon or Mugen Thermostate - You'll be in VTEC alot more, Stops Temp related problems. Doesn't take long to change, although it's not as easy as it looks.
Enjoy.
Enjoy.
awesome replies everyone... thanks!
and uh yeah.. it's a road course... no offense to those who do... but i don't think of the itr as a drag car...so brake pads... extra fluids... anything else....?
I've got RE730's on the r now... poopoo tires that i'll be happy to run into the ground.... prolly getting falkens next...
Anything else?
Anything else?
Rain_man
Jun 24, 2002 11:52 AM
ITR00-816
15
May 23, 2002 09:38 AM
RATEDR
Feb 20, 2002 06:49 PM
