will a ls dist work on b16 motor
Old Jun 24, 2005 | 05:36 PM
racingant's Avatar
Default will a ls dist work on b16 motor
will a ls dist work on a obd0 jdm b16 swap if i cut off one of the leg off the dist and if i do that will vtec still kick in the same or would it be better to get a gsr dist i did the 0bd0-obd1 conversion on my 91 civic si i ahve a ls dist i think it obd1 how can i tell if it a obd1 ls dist will it work
Old Jun 24, 2005 | 06:04 PM
racingant's Avatar
Default Re: will a ls dist work on b16 motor (racingant)
bump
Old Jun 24, 2005 | 07:43 PM
shawn_crx's Avatar
Modified by shawn_crx at 1:03 PM 6/25/2005
Old Jun 24, 2005 | 08:14 PM
swifty4u's Avatar
Default Re: will a ls dist work on b16 motor (shawn_crx)
96% sure it will work..someone back me up. I've seen stock cx dizzys on type r motors stock hf dizzys on b16's so it should work.
Old Jun 24, 2005 | 08:28 PM
91civicEX's Avatar
Default Re: will a ls dist work on b16 motor (swifty4u)
i have a ls dizzy on my b16. u just need to cut one leg off and itll work.
100%
obd1 distributor needs a obd1 computer
use a obd0 distributor if your using a obd0 computer
u can tell if its obd1 if the plugs are grey and square.
obd0 plugs will be circle and white
shawn_crx's Avatar
let me check... I have a ls and b16 dizzy in the garge somewhere collecting dust
Old Jun 24, 2005 | 09:17 PM
racingant's Avatar
thanks foe the help
Old Jun 24, 2005 | 09:53 PM
racingant's Avatar
thank for the help
Old Jun 25, 2005 | 10:00 PM
racingant's Avatar
BUMP
91 HONDAsaurus rex
Aug 6, 2008 06:09 PM
2poor2tune
Dec 26, 2006 03:00 AM
CbGirlSi
Feb 4, 2005 09:16 AM
hybridej7
Dec 25, 2004 04:19 PM
benjamin
Sep 6, 2004 10:08 PM
