REAR LOWER CONTROL ARMS (LCA)
which lcas can i use on my 88 hatchback...i bought tokicos but the struts dont fit on the rear...i need the lcas that use the u shaped struts....which lcas are those...are those from 89-91 ef and 92-95 eg????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by envysionHATCH »</TD></TR><TR><TD CLASS="quote">which lcas can i use on my 88 hatchback...i bought tokicos but the struts dont fit on the rear...i need the lcas that use the u shaped struts....which lcas are those...are those from 89-91 ef and 92-95 eg????</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kulangot »</TD></TR><TR><TD CLASS="quote">
so i guess i hit it right on the nail????
</TD></TR></TABLE>so i guess i hit it right on the nail????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si »</TD></TR><TR><TD CLASS="quote">89-91 CRX (si for sway bar)
tegs and 92+ civics are 1/16" longer.</TD></TR></TABLE>
so i cant use the 92+ civics??? or can i...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91whiteZCrex »</TD></TR><TR><TD CLASS="quote">get itr
why?....88's are the same....he needs 89 and up..
</TD></TR></TABLE>why?....88's are the same....he needs 89 and up..
you know, i didnt experience this 1/16" difference when i put all four EF, EG, DA and DC rear control arms next to each other. they all seemed exactly the same length. the only oddball was the DA arm had the shock mount further out, but thats it.
did you measure this yourself?
why?....88's are the same....he needs 89 and up..</TD></TR></TABLE>
so you can tell people you have itr suspension
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson »</TD></TR><TR><TD CLASS="quote">
did you measure this yourself?</TD></TR></TABLE>
I read it in a article the guy measured rear arms etc etc. and the fronts.
He found that all teg arms were 1/16" longer. (UCA, LCA, compensator arm)
maybe the rear uppers, but i was able to stick a bolt through each hole and they lined up. 1/16th difference, i dunno my bolt check would catch that since bushings are all worn and stuff and wouldnt necessarily show it. but i have just found this not to be the case of any difference. id want to make more closer measurements myself before i agree to it. thats just me.
i myself have made this check, i used si lca's, dx lca's, and da lca's. the dx and the si were the same except the sway bar mount, and the da was like the si (same lenghth, i put the bolts through) except it didn't have that little curve in it (why's it there? can't be as a sacrifice if you hit a curb, cause the subframe still bends first) and the shock mount was farther away from the wheel, thus effectively decreasing your rear spring rates a little.
in fact, i think tyson has the set of si rear lca's i used in that comparison, yes the bushings were bad, but they weren't to the point of allowing 1/16 of play unless they were maybe under a LOT of stress.
on a side note, tyson, how are those LCA's working out for you?
hmmm.. i forgot i took this pic. oddly, im not sure how you saw it either... i never reformatted it to a viewable size until now (at least i didnt have the file before)...
anyhow.. i believe this is a comparison of EF vs EG rear LCA. the EG arm doesnt have the rear sway link because no US EG had a rear bar stock.
as for the bend or no bend, i dunno either. it seems kinda random whether the arm has the kink or not, but i havent paid much attention to it to figure out any pattern if present.
so you can tell people you have itr suspension</TD></TR></TABLE>
ok...
i have aftermarket rear lca's made for eg's and they are alittle longer....but noting some washer's cant fix..
ok...
how do washers "fix" an incorrect length??
</TD></TR></TABLE>how do washers "fix" an incorrect length??
how do washers "fix" an incorrect length??</TD></TR></TABLE>
have you ever seen a rear camber kit for 88-91 crx/civic there just longer bolts and washer's...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bagpipe goatee »</TD></TR><TR><TD CLASS="quote">i know the washer trick, but you also need an alignment afterwards to correct your now apparent toe-in</TD></TR></TABLE>
yes i got a alignment after i put the camber kit on...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91whiteZCrex »</TD></TR><TR><TD CLASS="quote">get the new k-sport lower control arms, they are sick as hell. but tehy will make a good dent in the walet
These actually look pretty nice.. thanks.. i think i might get them myself.... They really aren't all that expensive.. still pricey.. but not bad
http://www.ksportusa.com/products/controlarms.html
Integra 90-01 KSP-LCHD02 $250
Honda
Civic/CRX 89-91 KSP-LCHD01 $250
Civic 92-95 KSP-LCHD02 $250
Civic 96-00 KSP-LCHD03 $250
</TD></TR></TABLE>These actually look pretty nice.. thanks.. i think i might get them myself.... They really aren't all that expensive.. still pricey.. but not bad
Honda
