Camber Correction Kit?
Old Feb 12, 2002 | 08:27 PM
InfamousRS's Avatar
Default Camber Correction Kit?
Last time I had my car alligned after I lowered it, they said wy camber was within spec and that I did not need a camber kit. Would a camber kit still be helpful to keep the camber a the optimum degree? My car is lowered about 2 inches on GC coil overs.
Old Feb 13, 2002 | 11:02 AM
itr0045's Avatar
Default Re: Camber Correction Kit? (BLK94RS)
IMO camber kits are a waste of money. That's what they are for though, to fix camber issues. So an snwer to your question would be yes.
Old Feb 13, 2002 | 03:22 PM
ForcedAccord's Avatar
Texas B*tch!
Default Re: Camber Correction Kit? (itr0045)
Why are they a waste of money when it saves premature wear of very expensive tires?
Old Feb 13, 2002 | 08:21 PM
flymecourageously's Avatar
New User
when they did an alighnment test did they give the spec sheet. i dont think so.a 2" drop will most definitely effect negative camber. you will notice the inside of your rear tires wear differently than your front.camber kits will in fact give your tires back their natural life
Old Feb 13, 2002 | 10:23 PM
itr0045's Avatar
Default Re: Camber Correction Kit? (flymecourageously)
They are a waste of money because you dont need them. If you want to aviod premature wear on your tires rotate them regularly. Unless you are roasting your tires all the time or something. All 3 of my integras were lowered and I have never used a camber kit. The tires wear fine, and my cars get driven hard and then driven to work. Don't waste your money man.
Old Feb 13, 2002 | 11:08 PM
seek167's Avatar
no matter if you rotate them every week the insides of you tires a going to wear. unless you ride on some tires that are not derectional. don't know how to spell.
Old Feb 14, 2002 | 07:27 AM
itr0045's Avatar
Default Re: Camber Correction Kit? (seek167)
Whatever, I disagree. I have ran directional tires on all my lowered cars. I have always paid a little more to get them rotated and balnced regularly. It's your loss.
Old Feb 14, 2002 | 07:31 AM
rota426's Avatar
Technically you should use a camber kit if you drop more than 1.5" but thats just the rule of thumb I've heard. If everyone has experience...then I guess you don't really need to bother.
PiZZaBoY7000
Dec 8, 2011 04:05 PM
91EF919
15
Jun 24, 2009 07:15 AM
98GSRDC2
Suspension & Brakes
Aug 17, 2007 11:10 AM
E36 Guy
16
Apr 7, 2006 09:58 AM
toooslow
May 7, 2003 12:38 PM
