Does RC make an injector that plugs into the factory OBDII injector harness
Old Jun 24, 2005 | 03:40 PM
98vtec's Avatar
moderator emeritus
Default Does RC make an injector that plugs into the factory OBDII injector harness
I would really like to get some RC's and not have to convert my clips to OBDI. Is this possible or am i gonna have to do the conversion? I'm gonna be running a p72 ecu with the injectors installed if that matters.
Old Jun 24, 2005 | 05:06 PM
98vtec's Avatar
moderator emeritus
Default Re: Does RC make an injector that plugs into the factory OBDII injector harness (98vtec)
bump
Old Jun 24, 2005 | 06:30 PM
mgags7's Avatar
hmm....i used my 96 h23 engine harness with my 94 jdm h22a injectors.....plugged right up....
Old Jun 24, 2005 | 06:46 PM
98vtec's Avatar
moderator emeritus
Default Re: (mgags7)
interesting.
Old Jun 24, 2005 | 08:24 PM
98vtec's Avatar
moderator emeritus
anyone?
Old Jun 24, 2005 | 09:05 PM
WickedSol's Avatar
What RC does make is obd1 injector clips, but your gonna have to sauder the wires onto your existing harness..
Old Jun 24, 2005 | 09:23 PM
98vtec's Avatar
moderator emeritus
Default Re: Does RC make an injector that plugs into the factory OBDII injector harness (SpdImge415)
so for instance:
http://cgi.ebay.com/ebaymotors...33554
and just buy the clips for 29 bux
Old Jun 24, 2005 | 09:47 PM
WickedSol's Avatar
are you looking for RC 370's? i just so happen to have a set for sale...i used them for just over 1 month before i went with hondata and some 440's...i'll sell them to you for 260 shipped...
they are RC 370cc Peak and Hold Injectors for 0BD1...if your interested..i'm sure i can find some obd1 injector clips laying around...just give me an e-mail if you'd like to pick them up...
btw...nice header! have you dyno'd yet?
Old Jun 24, 2005 | 10:04 PM
98vtec's Avatar
moderator emeritus
yeah i want 370cc. Whats the difference in saturated and Peak and Hold. I have been told to stick with saturated with the p72 ecu i have
Nope no dyno's yet. Waiting to get my cams, etc installed. and now i need injectors before i get it tuned on neptune.
Do you have AIM? IM me.
Old Jun 24, 2005 | 10:55 PM
precord96's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">yeah i want 370cc. Whats the difference in saturated and Peak and Hold. I have been told to stick with saturated with the p72 ecu i have
Do you have AIM? IM me.</TD></TR></TABLE>
The difference is in the resistance. Since you have a resistor box already wired in on your car you can use either Saturated(High Impedance) or Peak and Hold(Low Impedance) without any problems. The ecu has nothing to do with it, as long as you have a resistor box or not. If you have a resistor box then you can use either injector, but if you don't like most other cars then you can only use Saturated injectors.
import-tooner
Jan 24, 2011 09:14 PM
thanh4o8
May 29, 2009 01:17 PM
fortynineR
Aug 30, 2007 03:08 PM
TheSwift1
Jul 31, 2004 07:04 PM
Babybluegsr92
Aug 15, 2001 12:45 PM
