Fuel pump?
Old Jun 24, 2005 | 02:06 PM
brutus101's Avatar
Default Fuel pump?
Changed fuel relay on 93 accord still will not start. how do you access the fuel pump? The car ran fine, and occasionaly it would briefly start and quit. As long as you waited about five min. it would start Happened about 5 times then.... no more. I mean it left me stranded.
Old Jun 24, 2005 | 02:31 PM
deserthonda's Avatar
Default Re: Fuel pump? (brutus101)
why dont you make sure that it is fuel related first,, when car wont start, pull back tube that goes to throttle body spray some carb cleaner and see if car starts keep on spraying see if it keeps running .............if not you could have electrical problem,,,, ign switch, coil, ignitor
Old Jun 30, 2005 | 07:16 AM
brutus101's Avatar
Default Re: Fuel pump? (deserthonda)
Hey thanks for the imput. I tried the line at the throttle body, and I had great fuel pressure. Removed spark plug wire ,and didn't get any fire. Changed the distributor, and she fired right up.
Thanks once again.
Brutus101
str8kustomz
Honda Civic (2001 - 2005)
Apr 13, 2015 01:55 AM
str8kustomz
Feb 2, 2015 03:24 AM
mattstru
Apr 26, 2006 05:42 AM
crxxrc
Feb 8, 2004 01:39 PM
JolToN49
Nov 20, 2002 11:41 AM
