OEM Shifter
Old Jun 24, 2005 | 12:46 PM
BoBoChan's Avatar
Default OEM Shifter
ok, so i got the car and it had a lame shifter on it. my brother bought the oem shifter on ebay and it came in the mail today with the boot and everything. everything was ok.
i go to the car to install it.. and i take out the ricer one. then i see LOTS of debris in the lito ring holder. i try to clean it out a bit.. but its hard, i cant get ne of the rubber chunks out. so i say screw it and try to fit the **** in, it doesnt fit.. and i notice that there is a screw spot on the bottom of the shifter, so im like, "oh.. suppose to screw it in"
i attempt to screw it in.. and it turns out it doesnt fit.. the metal stick is too big to fit in the hole.. then i came to a theory, the shifter was already pretty low, it seemed lower than stock, and he did not install a short shifter. i look at the stick again.. and it is cut off at a weerd angle..
"did he cut the ****** stick?!?!"
so yea, can someone confirm if he DID infact cut it or.. im a noob that is mada mada
edit: pix are blurry... walk it off
Old Jun 24, 2005 | 12:52 PM
dj02's Avatar
Default Re: OEM Shifter (BoBoChan)
spell check is your friend.
the pic is blurry, but looks like some one cut it. or messed up the treads bad.
Old Jun 24, 2005 | 06:05 PM
cnyej1's Avatar
Default Re: OEM Shifter (dj02)
Take and cut the very top off with a hack saw.... it will work. Cut it as straight as possible. In my ricer days when i was 16, I cut my shifter and still was able to screw on a shift ****.....its just gotta be pretty straight.
Old Jun 24, 2005 | 08:29 PM
BoBoChan's Avatar
Default Re: OEM Shifter (cnyej1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cnyej1 &raquo;</TD></TR><TR><TD CLASS="quote">Take and cut the very top off with a hack saw.... it will work. Cut it as straight as possible. In my ricer days when i was 16, I cut my shifter and still was able to screw on a shift ****.....its just gotta be pretty straight. </TD></TR></TABLE>
?? the rod is a thicker then the screw hole in the shift ****. im thinkin this person cut off a thinner rod that was attached to the top of this..
Old Jun 24, 2005 | 09:26 PM
NiPBoi's Avatar
yea y0...he cut that ****...dam ghetto *** peeps
Old Jun 24, 2005 | 09:31 PM
cnyej1's Avatar
Default Re: OEM Shifter (NiPBoi)
Oh ok I see now.... yeah he cut it way to low.... Id just shell out the $50 for a quality shifter.... until then use a shift **** that uses a set screw.
Old Jun 25, 2005 | 12:31 AM
RsxVengeance's Avatar
******* ricer cut the shifter.........
Old Jun 25, 2005 | 02:52 AM
B00STidDc5's Avatar
buy a revo or a b and m shifter. it replaces the stock shifter completely. new thread, shorter throw, the **** will fit no problem
Old Jun 25, 2005 | 07:40 AM
cnyej1's Avatar
Default Re: (K20Allmotor)
Does Evasive make a shifter for your car? I bought one on here with the Honda-tech price and I think I paid $50 and thats because I bought the ES bushing too.
Old Jun 25, 2005 | 08:59 AM
BoBoChan's Avatar
Default Re: (cnyej1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by K20Allmotor &raquo;</TD></TR><TR><TD CLASS="quote">buy a revo or a b and m shifter. it replaces the stock shifter completely. new thread, shorter throw, the **** will fit no problem</TD></TR></TABLE>
yo can you hook me up with some links, because seriously.. the ricer shift **** is lame.. its like a square.., the inside of it is rubber.. he juss cut out a lito hole with a knife or sumthin and shoved it in til it fit.
ricers
Old Jun 25, 2005 | 11:43 AM
i'll sell you the revo for cheap, only thing you need is to weld it alittle bit.
Old Jun 25, 2005 | 12:16 PM
BoBoChan's Avatar
Default Re: (RsxVengeance)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RsxVengeance &raquo;</TD></TR><TR><TD CLASS="quote">i'll sell you the revo for cheap, only thing you need is to weld it alittle bit.</TD></TR></TABLE>
i dont know how to weld.. nor do i know ne one who has the tools.. sry :/
Old Jul 1, 2005 | 11:50 AM
dj02's Avatar
Default Re: (BoBoChan)
B&M
http://www.dezod.com/pd_bm_sho...g.cfm
revo
http://www.robearracing.com/cat_revo.cfm
EG-SIXV-TEC
Oct 9, 2011 07:06 PM
Understeer
Jan 15, 2011 07:57 AM
ebelp
Jan 21, 2005 02:47 PM
civicboisi
19
Aug 10, 2004 10:09 AM
MyLittleRedCar
Jul 19, 2003 10:45 AM
