important internals to upgrade for a turbo setup?
Old Jun 24, 2005 | 11:11 AM
redDAinteg's Avatar
Default important internals to upgrade for a turbo setup?
ok well ive made my decision and I will be going LS turbo once I get all my parts and right now i'm going to replace my piston rings and since I will be inside my block, is there any IMPORTANT internal parts I should replace/upgrade for turbo. I know stock internals have been proven strong for boost, but would getting some rods,pistons, etc. be necessary? i'm going to leave my stock cams and valvetrain, so basically i'm only worried about my bottom end. all advice is welcome. thanks.
Old Jun 24, 2005 | 11:17 AM
Vtecfool's Avatar
Default Re: important internals to upgrade for a turbo setup? (redDAinteg)
upgrade your rods while your at it.
Old Jun 24, 2005 | 11:27 AM
redDAinteg's Avatar
Default Re: important internals to upgrade for a turbo setup? (Vtecfool)
are the rods more important to upgrade than the pistons? because I know the compression 9.2 on the LS is perfect for turbocharging so thats good. im thinking about crower rods with stock pistons. what else guys ?
Old Jun 24, 2005 | 11:30 AM
BlueSi2k's Avatar
If you had to choose one I would say pistons because the stock ringlands are kind of weak. If the motor is open I dont understand why you wouldn't just throw some eagle rods in there. It doesn't really make sense to do one and not the other.
Old Jun 24, 2005 | 11:52 AM
YiNYaNg's Avatar
Default Re: important internals to upgrade for a turbo setup? (BlueSi2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueSi2k &raquo;</TD></TR><TR><TD CLASS="quote">If you had to choose one I would say pistons because the stock ringlands are kind of weak. If the motor is open I dont understand why you wouldn't just throw some eagle rods in there. It doesn't really make sense to do one and not the other.</TD></TR></TABLE>
Maybe the guy doesn't have a big bank account like you.
Everything cost $$$
Old Jun 27, 2005 | 05:27 PM
BlueSi2k's Avatar
Default Re: important internals to upgrade for a turbo setup? (H-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H-T &raquo;</TD></TR><TR><TD CLASS="quote">
Everything cost $$$</TD></TR></TABLE>
Its gonna cost him more in the end if one of those stock rods give out.
Nisif
Aug 30, 2012 09:55 AM
mcgee*
Jan 24, 2007 04:16 AM
redDAinteg
Jun 24, 2005 11:29 AM
Joel_MN
Aug 29, 2003 11:58 AM
JeremyL
Dec 7, 2002 07:15 AM
