carpeting a box?how
hey i was wondering what i should use to put the carpet on my sub box, staples or carpet glue, im not sure . let me know what u think i should do
I would suggest using some spray adhesive.......and in this case, you get what you pay for, so don't get the cheapest can you can.
Probably will run you about $6ish......spray it on both the carpet and the box.....let sit for a minute until it gets a bit tacky, they press them together - you should be good to go. Also, make sure to pay extra attention (i.e. put a bit more on) in the corners, or where seams meet.
Good luck.
Modified by pnthr30 at 10:50 PM 6/24/2005
Probably will run you about $6ish......spray it on both the carpet and the box.....let sit for a minute until it gets a bit tacky, they press them together - you should be good to go. Also, make sure to pay extra attention (i.e. put a bit more on) in the corners, or where seams meet. Good luck.
Volcom
Audio / Security / Video
Jan 2, 2002 09:51 AM
