oil pressure
Tee off the stock oil pressure sensor port.
You need a 1/8x28 BSPT Fitting to put in the block. DO NOT use an NPT fitting that you can get at the hardware store. You'll cross thread the block. Mcmaster carr (and others) sell the correct BSPT to NPT adapter fitting so you can use standard fittings. If you're using a Deft, HKS, GReddy, etc... sensor, you can just leave the fittings BSPT, because thats what the sensor screws into.
You need to hook the stock one back up (hence the T fitting) so the light in the dash doesn't go on.
itr1244
Sep 23, 2009 04:18 PM
vladd
Jun 26, 2006 07:18 AM
turbotime
Nov 29, 2003 04:58 PM
