2nd gear issues
Old Jun 24, 2005 | 01:02 AM
alphaquake's Avatar
Default 2nd gear issues
i rebuilt my ls tranny and swapped some good gsr internals over from a broken gsr tranny that had a huge hole in the casing. now every gear goes in while im driving but second doesnt, unless im making right turns. ...driving straight even if i double clutch it wont even get the damn thing in gear....i know for a fact its not a syncro problem because it goes in smooth (only making right turns) im thinking its my alignment becuase my car pulls slightly and my steering wheel is a little crooked so i have to hold it to make it drive straight. or my passenger axle is bad... my linkage is good. and i just flushed the tranny twice with honda MTF.... my 3 mounts have polyurathene inserts and theyre tightened. and btw this is a stock b20 on a del sol...........
im going to get an alignment soon... i think that may be the problem...
as i think about it though, before i overhauled the tranny 2nd gear was no problem..... possibility a bent fork inside?
anyone here experienced this???
Modified by alphaquake at 7:31 PM 6/25/2005
Old Jun 24, 2005 | 03:05 AM
Phoenix_ITR's Avatar
Default Re: 2nd gear issues (alphaquake)
that's a really weird problem...
it doesn't sound like the shift fork is the problem, but something is definitely binding in there. maybe a dumb question, but are you running axles that are the correct length?
-tony
Old Jun 24, 2005 | 08:51 AM
alphaquake's Avatar
Default Re:
they are actually the same axles i was using
Modified by alphaquake at 11:45 PM 6/24/2005
Old Jun 24, 2005 | 02:45 PM
alphaquake's Avatar
Default BUMP
bump
Modified by alphaquake at 12:20 PM 6/25/2005
Old Jun 25, 2005 | 03:21 AM
alphaquake's Avatar
Default Re: BUMP (alphaquake)
B U iVl P
Old Jun 26, 2005 | 07:49 AM
alphaquake's Avatar
bump,,,
ahh
Old Jun 27, 2005 | 12:10 PM
alphaquake's Avatar
ahhh forget it
MrExclusive
Feb 4, 2010 07:52 AM
ABlais
12
Jun 17, 2008 11:25 AM
No2Pencil
Oct 17, 2005 05:17 AM
HalfManHalfFred
Jan 14, 2005 07:51 PM
BlueIntegraBoy
Jul 25, 2004 11:57 AM
