does leaded gas kill wideband o2 sensors like it does stock ones?
Old Jun 23, 2005 | 07:33 PM
B16Civic93's Avatar
Default does leaded gas kill wideband o2 sensors like it does stock ones?
just curious. does leaded gas kill wideband o2 sensors like it does stock o2 sensors?
Old Jun 23, 2005 | 07:36 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: does leaded gas kill wideband o2 sensors like it does stock ones? (B16Civic93)
over time, yes
Old Jun 23, 2005 | 08:03 PM
blackeg's Avatar
Default Re: does leaded gas kill wideband o2 sensors like it does stock ones? (wantboost)
yes it shortens o2 sensor life
Old Jun 23, 2005 | 08:08 PM
B16Civic93's Avatar
Default Re: does leaded gas kill wideband o2 sensors like it does stock ones? (blackeg)
what type of time are we talking? a week, a month...?
Old Jun 23, 2005 | 08:40 PM
Dunc's Avatar
BCICAN
they don't measure it in time. They like to measure in miles. I think it was like 100,000 using unleaded and 10-20,000 using leaded.
Don't hold me to that, I forget the <U>exact</U> numbers. But I remember it being a HUGE drop in life span. So huge that it wouldn't be worth it.
Old Jun 23, 2005 | 08:43 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: does leaded gas kill wideband o2 sensors like it does stock ones? (Dunc)
i do beleive that leaded fuel isnt as bad as oxygenated and leaded fuel...
Old Jun 23, 2005 | 08:59 PM
B16Civic93's Avatar
meaning that leaded fuel is better than unleaded and leaded mixed?
Old Jun 24, 2005 | 01:46 AM
01geeser's Avatar
New User
correct me if i am wrong, but i believe that wb o2's die quicker than stock o2's.
Old Jun 24, 2005 | 04:18 AM
vtec.dc2's Avatar
Default Re: does leaded gas kill wideband o2 sensors like it does stock ones? (01geeser)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01geeser &raquo;</TD></TR><TR><TD CLASS="quote">correct me if i am wrong, but i believe that wb o2's die quicker than stock o2's.</TD></TR></TABLE>
shouldn't do that.. its likely they die faster because of tuning may involve runing really rich at first
Old Jun 24, 2005 | 04:32 AM
Pikachu's Avatar
That's not true. If you're constantly running rich on your wb02 then it will definately shorten the life. Under normal operation, it should last just as long as a stock o2 sensor if not longer.
Old Jun 24, 2005 | 05:59 AM
Dunc's Avatar
BCICAN
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16Civic93 &raquo;</TD></TR><TR><TD CLASS="quote">meaning that leaded fuel is better than unleaded and leaded mixed?</TD></TR></TABLE>
Well I wouldn't see why a mix could be more harmful than straight leaded...because wouldn't the mix be diluted or am I wrong on that? Either way, any amount of leaded is bad.
Old Jun 24, 2005 | 08:06 AM
B16Civic93's Avatar
then what do guys do when they tune cars running leaded race gas?
just burn up their o2 sensors?
Old Jun 24, 2005 | 08:15 AM
therealPROJEKTEG's Avatar
B A N N E D
well, if you're running leaded race gas at the track, and they're said to burn up around 10k miles, that's 40k passes down the track, so it's not like if you go to the track every week and make a few passes on you wideband it's going to burn up. on the other hand, if you can afford to run leaded race gas every day, you can afford to replace the o2 sensor every few months as well
Old Jun 24, 2005 | 08:40 AM
cuin9sec
Guest
Posts: n/a
si
TimeRacer
Feb 13, 2007 04:20 PM
amej8
Jul 3, 2005 09:58 AM
pr_tony_montana
16
May 13, 2005 10:14 AM
STrEet11SeCTurBoEG
May 10, 2004 04:36 PM
birz
Jan 14, 2004 04:39 PM
