T3/T67 H.O. with ported shroud
Old Jun 23, 2005 | 07:00 PM
Turbo200's Avatar
Default T3/T67 H.O. with ported shroud
Here you go. I decided to get this done while the turbo was sitting around waiting to go on. The problem was i couldent find anyone that offered this service, until i talked to O2induction.
If you are interested in getting this service done to your turbo.
http://www.o2induction.com
Modified by Turbo200 at 4:27 AM 6/24/2005
Modified by Turbo200 at 4:28 AM 6/24/2005
Old Jun 23, 2005 | 07:06 PM
EFB16ACRX
Guest
Posts: n/a
Default Re: T3/T67 H.O. with ported shroud (Turbo200)
would you mind explaining to us stupid people,(just me)what the point is?
Old Jun 23, 2005 | 07:17 PM
Turbo200's Avatar
Default Re: T3/T67 H.O. with ported shroud (EFB16ACRX)
In theory this should extend the lower end of the compressor map. So it should give me more midrange hp and torque and more peak hp.
Its designed to help smaller engine run larger compressor wheels.
HKS does it on their t04z
GT30r different style
Old Jun 24, 2005 | 06:24 AM
99_GS-T's Avatar
If the turbo doesn't surge without it, will a ported shroud help at all? It actually reduces the airflow capacity and of the wheel. Although it seems to widen the efficiency islands.
http://www.turbobygarrett.com/...d.gif
Old Jun 24, 2005 | 08:34 AM
Chip's Avatar
Default Re: (99_GS-T)
Ryan Woon from WOTM makes rings that you can insert in some anti surge turbos like the GT47's to make them a smooth inlet like a normal turbo, because apparently if the turbo doesn't surge at all they're seeing power losses from it. I think he picked up in the neighbourhood of 35 RWHP starting at 900 on his car when it had a T74 by eliminating the anti-surge and nothing else.
Old Jun 24, 2005 | 09:15 AM
project dc2's Avatar
Default Re: (Chip)
how about a technical reason of why it works.
Old Jun 24, 2005 | 09:39 AM
.RTErnie's Avatar
Default Re: (project dc2)
My turbo has the antisurge inlet much like the garrett pictured above....I'm not a big fan because its not coooool
Old Jun 24, 2005 | 09:48 AM
Default Re: (RTErnie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTErnie &raquo;</TD></TR><TR><TD CLASS="quote">My turbo has the antisurge inlet much like the garrett pictured above....I'm not a big fan because its not coooool </TD></TR></TABLE>
dont worry about it . i twill be soon !
{ Insert Bandwagon here}
Old Jun 24, 2005 | 09:53 AM
Kwuaymaikrup's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by project dc2 &raquo;</TD></TR><TR><TD CLASS="quote">how about a technical reason of why it works. </TD></TR></TABLE>
Technical shmechnical. It looks friggin cool, that's why it works...LOL.
Old Jun 24, 2005 | 09:54 AM
Default Re: (Kwuaymaikrup)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kwuaymaikrup &raquo;</TD></TR><TR><TD CLASS="quote">
Technical shmechnical. It looks friggin cool, that's why it works...LOL. </TD></TR></TABLE>
whats that ? ssautochrome theory ? if it blings they will come ? ( ill start blinging my manifolds brb ! lol jk
Old Jun 24, 2005 | 09:59 AM
whats that ? ssautochrome theory ? if it blings they will come ? ( ill start blinging my manifolds brb ! lol jk </TD></TR></TABLE>
LOL...naw really, I would like to know technically why it works or what it does. I already have enough pimp juice anyways.
Old Jun 24, 2005 | 12:05 PM
99_GS-T's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by www.turbobygarrett.com &raquo;</TD></TR><TR><TD CLASS="quote">A Ported Shroud compressor (see Fig. 2) is a feature that is incorporated into the compressor housing. It functions to move the surge line further to the left (see Fig. 3) by allowing some airflow to exit the wheel through the port to keep surge from occurring. This provides additional useable range and allows a larger compressor to be used for higher flow requirements without risking running the compressor into a dangerous surge condition. The presence of the ported shroud usually has a minor negative impact on compressor efficiency.</TD></TR></TABLE>
Old Jun 24, 2005 | 12:31 PM
Turbo200's Avatar
I did it for the simple fact that i will be running a 67mm comp. wheels on a 2.0l motor.
Old Jun 24, 2005 | 12:40 PM
DragSource's Avatar
Holset has been using this technology for a long time. Probably a lot of information out there about how/why it works in you look into the Holset line.
Old Jun 24, 2005 | 06:00 PM
timg's Avatar
The best reason- the GT30R sounds incredible with a ported shroud! I'm not sure how common surge is with the turbos that most Honda's run, but I can't hear any on my S2000.
Tim
Old Jun 24, 2005 | 07:04 PM
qksl2's Avatar
How much was it to have it done?
Ian
Old Jun 24, 2005 | 10:01 PM
J-Brooks's Avatar
Is there any real proof in a loss of power on hondas, if not I'd be interested in doing this also, so I am curious of how much you paid and the approxiamate turn around time.
Old Jun 25, 2005 | 07:33 AM
Turbo200's Avatar
Default Re: T3/T67 H.O. with ported shroud (qksl2)
The only negative thing i came across was someone one supraforums was saying they lost spoolup time. But he showed proof even when asked to. But if HKS and Garrett use this tech. on there turbos, i will too
The service is $200 it includes the ported shroud and polishing of the velocity stack (inside compressor inlet).
Contact Jon at O2induction,
SALES@O2INDUCTION.COM
He'll hook you up.
Old Jun 25, 2005 | 06:05 PM
b16sedan's Avatar
HKS and Garrett use this technology for when they're running turbos that are prone to surge. With how late boost comes on with the HO there is no compressor surge whatsoever, but having the ported shroud will make it spool later.
Old Jun 28, 2005 | 06:06 AM
99_GS-T's Avatar
I'm running a T67 on a 2.0L and getting 20 PSI by 4800 RPM with no surge. There needs to be a better reason then "it sounds cool" for me to spend $200 on a compressor cover.
The only benefit I see is it LOOKS like it extended the width of the efficiency island on the compressor flow map I posted above. It's hard to tell if it lowered the peak efficiency though. Obviously some turbochargers need it to keep from surging. But the T67 doesn't seem to need it to prevent surge at all. Now if it fattened up the efficiency islands it MIGHT be worth the $200. I bet it still wouldn't make any more power while not maxing out the turbo and it would probably reduce the maximum power potential that it can make.
Old Jun 28, 2005 | 06:09 AM
done's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">I'm running a T67 on a 2.0L and getting 20 PSI by 4800 RPM with no surge. There needs to be a better reason then "it sounds cool" for me to spend $200 on a compressor cover.
The only benefit I see is it LOOKS like it extended the width of the efficiency island on the compressor flow map I posted above. It's hard to tell if it lowered the peak efficiency though.</TD></TR></TABLE>
whats the point if your not surging?
Old Jun 28, 2005 | 06:24 AM
Boltz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo200 &raquo;</TD></TR><TR><TD CLASS="quote">In theory this should extend the lower end of the compressor map. So it should give me more midrange hp and torque and more peak hp.
I thought it was the other way around. I thought that they used the ported shroud housing so you can run a smaller turbo that would normally surge in a certain area in the map, but now that its shrouded the surge limit is changed. Allowing you to run a smaller turbo with a larger motor, while still staying off of the surge limit.
fastazzf22
Jun 24, 2008 11:56 AM
Ak_ef9
Oct 10, 2006 10:58 PM
C7LRL
Feb 18, 2005 07:19 AM
non-VTEC
Dec 8, 2004 12:17 PM
Finest
Sep 24, 2002 11:03 AM
