head swap??
Old Feb 12, 2002 | 05:14 PM
projectcrx's Avatar
Default head swap??
i have a 88 crx dx 1.5L can i do a v-tech head swap on it if so wich head, and what do i need for the complete swap
thanks cole
and what kind of hp am i gonna be lookin at?
Old Feb 12, 2002 | 05:38 PM
HCrip's Avatar
Default Re: head swap?? (projectcrx)
Yeah, you can mate a d16z6 or y8 to that motor. You can use the same ecu/distributor, if you want, but then you'll need to wire up a vtec actuator. Easiest way is to get the head/distributor/ecu as the samd OBD scheme. High compression motor, resembles the VTI in Japan. Around 125 hp. Also, you'll need a resister box and wire over to MPFI. Not very expensive for it all.
Old Feb 12, 2002 | 06:11 PM
Redline130's Avatar
If you can, use the D16Y8 head (96-up Civic EX). It will give you higher compression, has a good intake manifold design, and you can use a 88-91 distributor on it as well.
cyber13
Old Feb 12, 2002 | 06:51 PM
projectcrx's Avatar
Default Re: head swap?? (cyber13)
can u guys please put a complete parts list up with the years and type of cars it comes off thanks and is there any sites that tell you about this???
thanks
Old Feb 12, 2002 | 07:22 PM
Redline130's Avatar
Use the search function, look under "mini-me", you'll find alot of info.
cyber13
denniscoles
Apr 17, 2007 09:16 PM
sycotickid
Apr 9, 2006 08:19 AM
Layziebtnh055
Apr 29, 2004 01:44 PM
hondacivic4g
Aug 8, 2003 01:27 AM
