brake pedal way to low
i just installed full gsr brakes on my 93 vx i bleed all the corners twice. when i press teh pedal it goes almost all the way to the floor. i have not upgraded the mc yet could that be my problem??
You need a MC from a 91 Civic EX 4dr. This one is 15/16" (yours is 13/16"), and it's the proper size for a NON ABS GSR brake system. The 91 EX 4dr MC bolts directly to your existing brake lines & booster, so no need to worry about anything else. They cost about $140 brand new directly from Honda (www.hondaautomotiveparts.com or http://www.slhondaparts.com).
Also, once you crack open the brake system, I would go around to each wheel about 3-5 times, while bleeding about 8-12 pump/bleed steps per wheel per round...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostn5Ghaba »</TD></TR><TR><TD CLASS="quote">I would bleed it again. It sounds like you still have air in the lines.</TD></TR></TABLE>
or his master cylinder is inadequate.
b16_madman
Aug 30, 2005 12:34 PM
