ys1 cable - hydro interchange question
I have a 92-93 jdm YS1 cable tranny(the short geared one).. A friend of mine has a LS hydro tranny..
Is it possible to swap the guts from the cable YS1 into the hydro LS tranny.. I know the YS1 is built like the hydro trannies but in cable form so I figured I might be able to swap out the internals since im going to a 92-95 civic body now with a hydro clutch..
Will the YS1 diff work in the case also or will I need to use a different diff with the YS1 ring gear.. Also if the YS1 internals wont go into a LS hydro, is there any other hydro tranny that they will go into?
Any info on this..
Any info on this..
there is a way that you can drill and mount a clutch slave onto the cable trans so that you can use it in hydraulic cars. a couple of my friends have done this and have had no problems at all. i will try to get some pix so that i can show you. but that would be the easiest route and its not even hard to do.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by moomakudafi »</TD></TR><TR><TD CLASS="quote">there is a way that you can drill and mount a clutch slave onto the cable trans so that you can use it in hydraulic cars. a couple of my friends have done this and have had no problems at all. i will try to get some pix so that i can show you. but that would be the easiest route and its not even hard to do.</TD></TR></TABLE>
Sounds good.. Let me know when you find the pics..
Update on this.. The jdm YS1 cable internals will fit perfectly into the LS hydro case.. I had to use the ys1 cable shift forks, gear clusters, and diff.. The LS hydro shifter box and shaft can stay..
John The G
Transmission & Drivetrain
Mar 8, 2023 06:49 PM
DelSols-plural
Sep 21, 2011 07:25 AM
