Suspension & Brakes Theory, alignment, spring rates....
REALLY messed up
Old Jun 23, 2005 | 11:55 AM
Ghett0_ed's Avatar
Default REALLY messed up
ok guyz i dunno if this is the right place but i figured it was.....got an 89 hatch civic not sure of the model(si,dx,etc?? couple weeks ago i was driving on a wet road in wilsonville...i was goin around a turn and downshifted i got a little tire skip so my car went sidewayz...right into a curb,ouch, now my fronts all messed up i was jus wonderin if n-e one cld gimmie a guess as 2 whats wrong with it...i now the rim, fender, rotor need 2 be replaced but wut else...my friend suggested the upper ball joint ,does that sound right?? n-e ways let me now i really appriciate it guyz
pic didnt work heres the link to my yahoo album http://pg.photos.yahoo.com/ph/.../7408
Old Jun 23, 2005 | 12:12 PM
eMpAtHy's Avatar
Default Re: REALLY messed up (BlackGSRhhatch)
lca is probably bent.. see if ur axle is messed up. it's not worth fixing. get rid of the car. buying used parts for the car alone will cost more than what the car is worth. go get a new car. that car is worth like 700 dollars if ur lucky :\
pull ur DOHC and part out the car and buy a new one for like 700 dollars
Old Jun 23, 2005 | 01:26 PM
EKhybrid's Avatar
Default Re: REALLY messed up (eMpAtHy)
yes get rid of it!!!! The same thing happend to me!!! I messed up a whole alot of SH**!!!!
Old Jun 23, 2005 | 01:35 PM
Ghett0_ed's Avatar
Default Re: REALLY messed up (EKhybrid)
bummer i luv this car
Old Jun 23, 2005 | 09:52 PM
Ghett0_ed's Avatar
any other opinions???
Old Jun 24, 2005 | 04:41 AM
91civicDXdude's Avatar
buy the parts at a junkyard and dont listen to these fools.
Old Jun 25, 2005 | 12:41 AM
TrueUntilDeath.com's Avatar
Default Re: (91civicDXdude)
same thing happened to me a while ago. i broke my rim, and bent my lower control arm. you might have bent the crossmember also.
go to a dismantling shop/yard to see if you can find replacements.
Old Jun 25, 2005 | 06:25 PM
cheesebox's Avatar
Default Re: (FrostWhiteDC4[Loveless])
keep the car and go here for parts if your area salvage yards don't have alot avail.
car-part.com
good luck
Old Jul 1, 2005 | 08:01 AM
Dustin L's Avatar
Default Re: (cheesebox)
There is a more likely than not possibility that the car will never be the same. Think about it, you just impacted at speed, your entire front right (or left maybe I guess) suspension into the side of your car. There was once a guy on the ITR forum a couple years ago here that had a similar incident at lower speed with no visible damage. It cost him several thousand to fix it. You will definitely have to take the car to a bodyshop or chassis place and have them pull out that side a little. When you impact steel, it bends. Your car's chassis is no exception.
Andrew-L
Dec 25, 2008 07:05 PM
LeaveMeAloneClifford
Jun 8, 2008 06:27 PM
dc4teg95
Oct 15, 2007 11:59 AM
hondaracin24
Jan 13, 2005 04:20 AM
hb_racer
12
Mar 29, 2002 05:30 PM
