VAFC problem
Old Jun 23, 2005 | 10:17 AM
Superman137's Avatar
Default VAFC problem
Ok I have a 92 accord with an h22a in it I hooked up my vtec controller and now it wont let me rev past 6800 does anyone know what the problem could be, the only code i'm throwing is a code 41 which it has been on before I hooked up the vtec controller.
Old Jun 23, 2005 | 12:17 PM
213374U's Avatar
0x5359-0055
Community Builder
Default Re: VAFC problem (Superman137)
Not positive (just guessing) but I don't believe the VAFC allows you to bump your stock rev limit settings.
Someone correct me if I'm wrong
Old Jun 23, 2005 | 08:31 PM
HaOcNcDoArd96's Avatar
check the wire connections going to the ecu esp. the vtec singal wire. I had just about the same prob. with my v-afc it just turned out to be a bad sodder. another solution would possibly be resetting all the setting set on the v-afc and see if that helps good luck
Old Jun 23, 2005 | 08:52 PM
Nick H's Avatar
New User
Default Re: VAFC problem (HaOcNcDoArd96)
not to try and make you sound ignorant, but check the easy stuff like making sure it's set to 4 cyl. and not 6 (i made this mistake)...and no, the vafc doesn't allow alteration of the rev limiter...
Old Jun 23, 2005 | 08:57 PM
h22a93lx's Avatar
i had the same problem the only way to fix it is to get a chipped ecu .... i got mine and now my rev limter is at 8500
Old Jun 24, 2005 | 08:48 AM
Default Re: VAFC problem (h22a93lx)
I just reset it and changed the cylinders and the sensors and everything is fine now. Thanks guys for the help.
Daily Interlude
Nov 5, 2004 06:11 AM
TGUNNER
Apr 18, 2003 10:18 AM
billk2k
Mar 7, 2003 12:03 PM
KC GSR
Aug 31, 2002 10:51 AM
DOHCVTECDELSOL
Apr 30, 2002 05:45 AM
