RPM Surging when reach temp.. coolant?
Old Jun 23, 2005 | 10:00 AM
FullEffect256's Avatar
Default RPM Surging when reach temp.. coolant?
I just took my head apart for repair, got everything back together...now when the car reaches temp, the rpms go up and down up and down... i seem to believe this has something to do w/ the coolant...from what i can see, it's not low, because i can still see the coolant sitting at the top of the radiator. any idea of what this could be?... thanks
Old Jun 23, 2005 | 11:22 AM
djmota's Avatar
Default Re: RPM Surging when reach temp.. coolant? (FullEffect256)
sounds like a vacume leak. check all hoses and make sure your intake mani is not leaking.
Old Jun 24, 2005 | 05:28 AM
I just checked all the hoses and even redid the intake manifold bolts w/ permetex layer on the gasket... still getting the surging...
if it makes any difference, the coolant i'm running is pure water, i'm just trying to flush out the system cuz some nasty stuff got in there when i was cleaning the piston tops....
also i'm running it w/o the radiator cap to let air bubbles out... but it doesn't appear that the coolant is even moving, it's just sitting in the radiator... any ideas? thanks
SeanK325
Jun 22, 2010 02:52 PM
giantdny
Nov 6, 2006 07:13 AM
AllMotorDA9
Oct 27, 2005 03:49 PM
Bunzino
Nov 11, 2003 10:00 PM
